- Room EQ Wizard Sound Blaster Audigy 2 ZS
- Frequency response of AVRs?
- Amplitude at Crossover Frequency
- REW not recognising USB Midi cable
- learn from my mistakes.
- DPL2 and REW
- 1st attempt at REW
- Lose EQ Correction Settings Between Measurements?
- input level not stable with ecm 8000
- Making progress, continued help appreciated
- What do you think?
- REW Issue #1: Calibrating SoundCard
- First graph
- rew wiring connections
- No change after BFD...
- Live Pro Sound - Is REW Applicable??
- REW trouble with LF Waterfall
- Importing Low Freq Data from ETF?
- More than One Listening Positions
- Post BFD results....
- am i doing something wrong ?
- Getting ready for REW?
- computer recommendation for REW
- First REW graphs - Advice pls
- REW okay for high frequency analysis?
- 1st attempt at roomeq for sub advice needed.
- After REW......should I be concerned about?
- EQ'ing of main speaker bass drivers?
- Noob wondering about imic sound card
- newbie needs help getting started
- External sound card question
- Might Be In Over My Head
- Calibration – Cant get a Flat response ? CM-140 & DSP1124 & REW
- Sound blaster live 24 installation
- REW on mac
- Software EQ
- No Repeatability
- Some what OT, but use REW to test TT isolation.
- Does this plot look reasonable?
- SUB PLOT - Would you add the filters?
- Behringer ECM 8000 for $50 shipped.
- Do they make this kind of cable?
- REW vs SpectraLAB
- SoundBlaster MP3+ feedback issue
- 1st Graph--how's it look?
- Can I use this Mic?
- C.E.M. DT-8850 SPL Meter?
- New to all of this - my first measurement
- Could this be improved?
- BFD/REW versus Auto-Room Setup
- Swept Sinus is no Sinus ?
- Sound Card Calibration Problem
- A newbie with a sound card/os question.
- Just another lurker...
- Initial room response graph help
- Parsing Error Creating Make Cal file
- First graph
- question on REW vs DEQ2496 BW(oct) units
- Is there a way to use REW to help to adjust time delay between main and subs?
- First Galaxy 140 results.
- :scratch: Cannot seem to get started?
- BFD Input Level?
- basic workflow clarification
- Filter Question
- What's an OK soundcard impulse response?
- Soundcard: PC vs USB for laptop? 16 vs 24 bit for REW and more?
- DRC and REW
- Need help with REW - can't get reasonable measurements
- Comparing SPL Meters
- High, Low Damping - which is better?
- BFD | REW for main speakers w/0 sub?
- Lap Top Computer for REW
- Some graphs, any suggestions
- what am i doing wrong?
