- Newb set up
- A couple of basic questions for the Soundblaster live! 24 bit external
- calibration confusion!
- OK.. where to start ?
- Calibrating - Hercules Fortissimo III 7.1 [Resolved]
- REW can't get a non corrupted reading
- Questions Before I Try
- My first measurements, please be kind :)
- Before and After - no BFD
- What did I do wrong?
- Room response with a Monolith (dip assistance please)
- Just ordered a bunch of stuff, anything else i need?
- Took some measurements
- Midi issues...
- Please help, I may be having problems setting up REW correctly
- REW: time sync issue for impulse response
- Soundcard Connections
- SPL meter problems
- Newbie - Is this what I am looking for?
- Sub Phase Effect
- Awesome program John!
- got my bfd - first graph i need help
- soundcard calibartion question
- House Curves and Setting Speaker Levels
- Reference Earphones with REW and Convolver
- Changing The Posted Graph Parameters...
- M-Audio Fast Track Pro setup help
- SB live external line out?
- Can REW measure using an external sweep?
- Microphone for EQ Room Wizard
- First REW graph attempt - HSU3.3
- New JL fathom 113 Graphs
- How can I tell REW how to define a PEAK?
- Changing receivers changed my sub phase - normal?
- Passing REW EQ settings onto the DEQ2496?
- No peaks to correct, but they are there!
- Can I still run the 2nd to last REW??
- REW Virgin 1st results
- "No peaks to correct" message from REW
- Who knows about low frequency room modes?
- Second Time is the Charm with new REW
- 50 hz dip
- My first measurement graph, what is wrong??
- Stereo subwoofers with RoomEQ & a FBQ2496
- Is the Sound Blaster Audigy2 ZS Notebook a good choice?
- Can't calibrate sound card!!!
- Please help with hardware setup for REW
- First attempt at REW - Could use some quick feedback (no pun intended)
- Check levels too low
- Low measurement with REW?
- Calibration Mic Calibration?
- what's best place for sub?
- REW w/software EQ?
- I need clarification of this pic.
- Interrupting Impulse Response
- First timer questions.
- REW - sets up right but then "check levels" too low
- Back to Square One
- Will ADS Technologies Pyro A/V Link work with REW?
- Converting 12db slope to BW Oct values I need for BFD
- Newb to RoomEQ
- My housecurve, REW, FBQ2496 & SVSs
- Two graphs, one normal and the other one corrected by the HK avr-635...what you think
- Latest REW graphs of my budget sub...
- A Welcome Surprise
- Help with 15dB dip 24 - 40Hz
- Problem with Room EQ Wizard running Vista?
- Did I do this right? Waterfall Graphs
- Mac revisited
- help!
- What to use for input
- Sound Card Calibration Problems
- Questions about my subs response.
- impulse response....
- Is rca mono to 1/4 stereo ok???
