- Calculating Freq Response, never ending?
- Sub level post house curve
- External sound card
- RoomEQ help
- Some measurements (and discussion)
- REW "Left Channel" Calibration Question
- Sigmatel Audio - Will it work?
- Getting Started - Microphone Requirement
- REW can't see DIGI002 i/o
- First bass measurement question...
- Problem settings input level in REW
- Anybody tried a USB-to-Serial adaptor?
- Using REW to investigate xovers in old receiver
- REW Mac OS X problems
- Any way to limit gain to +/-10.0 dB?
- Set up question
- REW and BFD Results
- Please critique my proposed set-up
- need some help calibrating
- Crashing A Lot (Mac OS X)
- Using REW to test outboard gear
- reducing peaks question..
- REW: Export Filters Response as wav
- USB to MIDI interface...
- Bergo´s Graphs
- Cowboys in my IB?
- sweep or sine wave ?
- Filters only above 100hz
- soundcard calibration check.
- First Round w/ REW -- Mixed Results
- accuracy of REW for full range measurements?
- Inconsistent Results
- Error Message on Windows Vista
- sub localizing
- House Curve Options
- Sub volume on A/V processor
- Using REW filter info
- Help! REW RS SPL correction seems inverted?
- Can REW be used to diagnose a speaker?
- Hello Folks
- My first measure
- About EQ Wizard???
- Room Eq Wizard
- Error in Help ?
- Target response / House curve
- FINALLY got the USB soundcard, now I'm ready to tackle REW!
- Did I get my sub equalized right?
- Just getting started
- New to the Shack, my first BFD graph :)
- Setup: Have I done it correctly?
- The dreaded "little endian not supported" error
- Response graph
- New to REW, few questions to get me started.
- High Low frequencies
- Waterfall interpretation
- 100+ dB at 10 Hz?
- using the DEQ 2496 with rew, warning, mainly graphics.
- EQ'ing my new IB
- Anybody in Eastern PA would like to help in with REW
- REW with M-Audio Fast Track Pro
- Baseline graph 15-200Hz sweep - do I need bass traps?
- Are the following sound cards suitable for the REW?
- New sub, some same old questions
- REW crashing on Intel Mac - why?
- Order of Calibration?
- REW and DRC
- New Sub: Monolith Response, any thoughts?
- SB Audigy 2 Platinum and REW
- Set up problems, looking for help pls
- Hsu VTF-3 HO REQ results....suggestions?
- phase shifts
- First post with pic. Hello!!!
- help with creative mp3 soundblaster setup
- SB MP3+ or M-Audio for laptop
- Data (correction values) beyond 100Hz?
