PDA
View Full Version : REW Forum
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. First measurements
  2. My first REW try.
  3. Newbie learning REW...
  4. Is Full Range EQ a no go?
  5. A few good subs with REW
  6. What would you prefer? Good average or perfect sweet spot?
  7. Boosting...Is it always bad?
  8. First REW measurement please comment
  9. Guideline for selecting crossover setting for Stereo listening?
  10. REW compatibility with ASIO based EQs
  11. Measurement volume always low
  12. Binaural MIC with REW?
  13. Sound Card issues? - Check your Connections!
  14. Weird Looking Calibration
  15. Can someone explain GATING in response measurements?
  16. subwoofer pre-out response doesn't seem right
  17. Using REW with Eq that is all digital?
  18. Creative X-Fi sound card and REW connections
  19. REW and Java issues on Mac OSX 10.5 - possible fix
  20. Suggestions for external sound card for notebook
  21. Trying to hook up to use REW w Apple laptop
  22. Differences between RCA cables
  23. Smooth FR plot vs. lowering decay
  24. Cannot generate waterfall
  25. Next step up from Radio Shack digital SPL meter?
  26. Another newbie with first measurement - opinions appreciated
  27. DEQ2496 in Rew
  28. REW - Problems Saving mdat + JPEG files
  29. Need a wee bit of REW assistance
  30. Linux Java startup error.
  31. bizarre sound card response!
  32. acceptable 250Hz-20Khz range deviation?
  33. Will this REW Setup work? RS SPL -> Line-in + COAX OUT -> Stereo System?
  34. Trying REW for the first time, Problem
  35. REW .cal file correction factor + SPL meter reading = true SPL?
  36. First Response...doesn't look right
  37. Severe error loading REW - please help.
  38. SPL Calibration with EMC8000
  39. Help with REW, SPL and receiver
  40. My first attempt.....how does it look - what next?
  41. First Look
  42. Subwoofer inverted impulse response
  43. REQ setup
  44. REW-totally lost
  45. Using REW with RME Hammerfall Digi 9632/52 (Not HDSP)
  46. download REW & java = :gah:
  47. Finding response of input/output seperately
  48. Smoothing function in new REW version?
  49. Have to restart REW for each measurement
  50. Something is amiss
  51. BK Monolith with REW + BFD
  52. A few (hopefully simple) questions
  53. A question and proposal
  54. Dave's adventures with REW
  55. dbx RTA-M or Behringer ECM8000 for REW
  56. First graph - Is this to good??
  57. Trouble calibrating sound card
  58. REW not generating a measurement signal
  59. Radio Shack SPL meter broken?
  60. REW is GREAT!
  61. Initial REW Setup
  62. Would Appreciate Suggestions
  63. Getting setup to run REW....
  64. First measurments, with and without eq, Velodyne IC 600
  65. Guys help! I am so stupid!!!!
  66. Response drops 50db at 8K into hash - Soundcard?
  67. New person-calibration help with MOTU card
  68. Mac Powerbook G3 and REW?
  69. Problem Graphing Waterfalls
  70. Large Room Eq setting with REW
  71. First REW attempt: IB with 4 AE-IB15 drivers in ceiling
  72. Which came first... the seating or the sub?
  73. First REW Analysis - Voiceover Studio
  74. System Calibration vs. Program Compensation: Will a house curve deliver sonic bliss?
  75. Convolver config file filter list
