- Is the film industry's X curve suitable for home theater?
- Soundcard problem
- Comments on my first measurements?
- Clipping Detected - Why?
- M-audio mobilePRE on Vista?
- REW and Digidesign Interfaces
- Using RTA to position subs/mains
- when new version of REW is coming out?
- House Curve Question
- Another "Does my Soundcard Cal graph looks okay?" Thread
- Phase issue, or what?
- Got the basics, now need to get to grips with the technical stuff!
- Can't calibrate soundcard
- REW working first graph post Kappa 12VQ
- Soundcard Calibration L/R Difference
- Using REW to find best sub location
- no sound on linux
- Question about main and sub intergration
- New to REW calibration problems
- ECM8000 Connection Issue (ground loop?)
- To Clear Calibration Process Set Up Concepts
- New feature for REW?
- Looks like REW can help me too
- Just purchased ECM8000 and MP13
- Audigy 2 NX Soundcard ok for REW?
- REW for me or not?
- Delayed start of measurement
- New first REW run with everything calibrated correctly!?
- SPL Calibration question
- First attempt at REW after several amatuer adjustments
- Can't calibrate my soundcard
- My First Measurement
- Another new REW user: first graphs
- Cannot calibrate creative x-fi soundcard
- REW and 1820m
- First shot at REW w/graphs
- Attempted to dampen the back wall
- Adding a second sub: not the same as primary...
- First Attempt to Measure Dual SVS PB13 Ultras
- First room measurement - graphs inside
- Sub position/phase graphs
- Is any of the EQ Simulators in REW comparable to Inguz?
- C Weighting Setup Questions
- Calibration help?
- Calibration 20db off?
- First graph with DIY sub
- Help, No Input mixers available - error
- 1st attempt charts : looking for advise
- Mains have wild response compared to subs, is this normal?
- Where to find Tripod
- Going back to old laptop and SB USB Ext Card
- Exporting IR as pcm file?
- .cal file for Audessey mic
- Anyone measure in car?
- RS meter woes II
- Tascam 144 calibration
- Starting Over. Sub EQ, Speaker EQ, room treatment
- Can REW create IR wav files for convolution?
- REW is a time saver! - First Graph
- REW: Stuck making first measurement
- REW graphed without a mic?!?
- DIGITAL RS meter woes
- REW distortion measurements
- How's my house curve?
- "Assign filters" is grayed out, why?
- my first graph.
- Help using MOTU Ultralite with REW
- Advice on HT audio setup
- Hmm, that doesnt sound like a sine wave
- Cable question?
- How do I create and save a Hard-Knee curve?
- SB X-Fi - which "mode" to use when calibrating ?
- sound blaster X-FI calabration Help
- Calibration files - not radioshack
- Signal Chain Question
