PDA
View Full Version : REW Forum
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. first time in 4 years to use REW
  2. PB-13 Ultra Fun
  3. My measurements - looking for comments
  4. Reservoir JBL’s full range “Lets go to work”.
  5. RT 60 in small rooms (useful?)
  6. Can I set the measurement level to say 85dB for RT60 due to poor S/N
  7. Difference in input levels when "Check Levels in settings" and "Check Levels in Measure"
  8. Need help - new user
  9. New user with a few questions about measurements
  10. New pics, low pass fully open
  11. Messed up target curve for subs
  12. Advice on measurement
  13. Moving the microphone instead of the subwoofer
  14. How to set the initial 75dB level for REW?
  15. Logarithmic graph frequency scaling question...
  16. Slaughter House House/Knee Curve
  17. Alright, here's my soundcard calibration graph
  18. Should I apply more EQ to deal with the mains?
  19. First Sub measurements, What does it say?
  20. Phase Plot
  21. Rew system and soundcard. Am i ok?
  22. Home studio measure.
  23. REW Newbie....
  24. Subwoofer set up for two-channel
  25. Presonus Firestudio
  26. Getting mains and subs in phase (group delay)
  27. REW feedback?
  28. Trying to understand how to do a hard-knee house curve
  29. Yes I'm new with another soundcard question
  30. Soundcard cal file correction to actual readings
  31. first graph what should i do now
  32. Avr question
  33. Attempting REW with a Digi 002R
  34. Acoustic-X
  35. Which type of soundsource (normal LS - OMNI LS)
  36. iPhone SPL meter, instead of Radioshack?
  37. Checklist Before I Order
  38. Setting up stereo sound and measuring help
  39. Generator signal not continuous
  40. Can I use the newer X-Fi Soundcard as alternate to SB Live 24bit?
  41. Opinions Please
  42. ...and then we add the mains
  43. need help getting started
  44. Influence of loudspeaker frequency response
  45. Slaughter House Cinema Revisited
  46. Soundcard Cal File
  47. My first attempt.....how does this graph look?
  48. BFD or Not
  49. Java error
  50. Waterfall Plot Perspective Control (Turn Off?)
  51. Please critique my graph
  52. 1st results and a reverb problem.. Quite a challenge!
  53. Does REW filters include some element of time correction
  54. First time, some help needed
  55. Differences between measure and generator
  56. first measurement
  57. Some guidance please
  58. REW, M-Audio Fast Trac Pro and Vista 64 Bit
  59. REW+PEQ and Audyssey problems
  60. M-Audio Fast Track Pro problems...please help
  61. M-Audio MobilePre Soundcard Calibration
  62. Can a laptop internal soundcard be used in REW?
  63. Phase correct ?! (Stereo) Impulse Pics_PLEASE HELP
  64. “In & Out” REW Frequency sweep
  65. SPL Calibration value - 75dB (too low?) for RT60 meas. in a classroom
  66. REW finds peaks but doesn't find valleys???
  67. Bad hum and buzz
  68. RS SPL Meter + soundcard OR Behringer ECM800 + mic preamp
  69. Tascam 144 calibration
  70. Measuring RT60
  71. Intel iMac Soundcard problem
  72. Very low signal level
  73. Try to EQ Sub plus L/R powered mains?
  74. Taking sweeps with both mains/sub or just one main/sub?
  75. First posting (here) of REW graphs...
