- Does REW filters include some element of time correction
- First time, some help needed
- Differences between measure and generator
- first measurement
- Some guidance please
- REW, M-Audio Fast Trac Pro and Vista 64 Bit
- REW+PEQ and Audyssey problems
- M-Audio Fast Track Pro problems...please help
- M-Audio MobilePre Soundcard Calibration
- Can a laptop internal soundcard be used in REW?
- Phase correct ?! (Stereo) Impulse Pics_PLEASE HELP
- “In & Out” REW Frequency sweep
- SPL Calibration value - 75dB (too low?) for RT60 meas. in a classroom
- REW finds peaks but doesn't find valleys???
- Bad hum and buzz
- RS SPL Meter + soundcard OR Behringer ECM800 + mic preamp
- Tascam 144 calibration
- Measuring RT60
- Intel iMac Soundcard problem
- Very low signal level
- Try to EQ Sub plus L/R powered mains?
- Taking sweeps with both mains/sub or just one main/sub?
- First posting (here) of REW graphs...
- REW setup question
- REW newb
- What action to take after measurement
- First Graphs please help
- Convert measurement to cal?
- sound card measurement
- Is there a thread that tells you what the results on REW mean and how to correct the room from an ..
- I Think I got it !
- sound card problem
- Computer in room 1/2 floor down from theater
- Tutor in Atlanta? I will pay for the jumpstart
- Need help with REW graph reading and input level
- REW on OS X 10.5 and DIgidesign Mbox
- Using REW to close mic a sub
- Graph at high frequency
- New day New Waterfall
- I don't think I'm doing it right.
- REW filter settings
- Connection Question
- First Post, First Graph!
- waterfall charts need input
- Weighting, limited bandwidth Pink PN, room gain?
- Setup/REW....Video Chat....Mac...HELP!!
- First up graphs, advice appreciated
- A few new measurements
- Behringer UCA202 calibration
- Background noise or room acoustics?
- Feature request for REW... The response of the human ear
- First FBQ2496 attempt.
- Problems with waterfall plots
- C-140 hookup problem
- How does my FR look?
- Help with REW!!!
- REW for nearfield monitors
- Q: Pin Point Wall Treatment
- Pink noise problem?
- 2 Channel guy with SET amp and Horns going to use REW - Suggestions wanted.
- Optimizing NHT Xd systems with REW
- My First REW Measurement with PB13
- First Measurements
- Another new rew user
- My first stab at REW
- Dell D620 Soundcard vs MobilePre Calib-both bad??
- Here's my first try
- Looking at crossovers with the Spectrum Anylizer
- Just hooked up REW and it haven't quite clicked..
- Can REW/BFD be used to tune home studio?
- Audio Problems.
- How can I enable the grayed out features?
- Galaxy CM-140
- 1/3 smoothing
- My first REW Graph
