- New to REW
- My first room analysis, but not with REW.
- Waterfall Plot Q
- Using REW with internal Creative SB Audigy 4
- Can't even get started!! REW & E-MU 0404 PCI
- REW Results.. Thoughts?
- Full range measurements & averaging
- 1st time setting up BFD
- REW and Java Version
- REW setup with Protools HD system
- Simplified Mic setup recommendation
- How imnportant is soundcard calibration?
- soundcard feedback loop
- peaks vs nulls
- SPL Calibration
- Lost graphs, unable to view in folder?
- Anotomy of the measurment graph
- Does REW use TDS (time delay spectrometry)
- New to REW. Opinions on results..
- How does my full response look like?
- What does dBfs tell us
- REW question
- How to get Sub graph with AVR's crossover?
- Using REW in a Recording Studio
- REW levels compared to Dolby reference
- connection ?
- Noob question: all my measurings look flat
- New to REW. Please help to get started pls!
- Does this look right ?
- What does "Good" look like ?
- could someone explain this please?
- Speaker Level Disparity
- Can someone check my work?
- ETC and determining speaker alignment
- No Input with USB Mic
- Dual 3.3 Turbos with Dual MDM-12s graph
- Why is the 1st spike at zero?
- Which view is accurate?
- First Post, First Measurements, Challenges Lie Ahead - Please Help
- dip in HF with 2 speakers
- Problem running REW: can't load standard profile
- BFD or DEQ 2496
- REW working with the DEQ 2496 Equalizer?
- NEW Slaughterhouse calibraton (Dual eD A2-300's)
- REW for speaker design
- My Measurements Continued
- Panel and sub measurements
- Taking mic readings...
- Need Advice
- Pick a winner
- setting up sub and mains
- REW SPL cal craziness
- Rerun Audyssey?
- all my waterfall plots look like this one
- Gap in my response
- What cable would I need
- My ETC graph
- Forgot to save my scans
- Calibrating like subs using REW and BDF
- New test equipment questions
- 2 inches...
- I sure hope I am doing something wrong
- Running receiver with no load - safe?
- how to read an impulse response?
- The distance readout is wrong
- First Graph
- soundcard and mic cal pics
- Ready to Jump In
- How to measure direct response of speaker ?
- Please helpa noob with some graphs
- to produce the sweep with the inserted correction?
- Can I use REW to...
- Some measurements I took..
- Impulse measurements
- connection queston
