- Use REW to test fabric for acoustic treatments
- What do you all think of my HT?
- measuring noise criteria with REW
- Room eq wizard on Mac...
- How does this graph look after BFD?
- The Home Theater Shack $2500 CASH Giveaway REW Graph Thread
- Now What?
- What sound card should I get for a Mac
- Check Levels Problem
- Subwoofer response, Is this normal?
- What volume controls to use once filters installed?
- OK, got some graph's, need advice...
- REW with Presonus Firestudio
- Strange noise with REW...
- Why are options grayed out?
- Wave Volume and Output Volume
- What do I do AFTER I upload REW filters to the BFD?
- signal noise soundcard ??????
- Does this look any good?
- Trouble Calibrating Soundcard
- Not sure if this is disturbing, or encouraging...
- Soundcard calibration problem
- Am I cablling this correctly?
- Connected...ready I think...now what?
- Help clarify soundcard requirement
- Export measurement as text: request
- Check my Results for me please
- Difference between curves?
- Measurement without impulse test?
- How to correctly use REW for home theater room measurements?
- REW and BFD FBQ2496
- Large Room Application of REW
- Surround Measurement - Check My Results?
- Noob to sound measurement has a basic question
- REW & varying Volume offers Different peaks & valleys
- New user with graphs, I think they are wrong
- Very new to REW and Shack
- another rew noob
- Soundcard and Cable lengths for SPL and AVR
- trying to wire/calibrate w/ recording studio equipment
- How to start measurements when you have multiple subs
- Next Step - Measurement graphs do not look valid
- Help: RS meter reads +4 dB during level check
- EMU-0404 Calibration
- My room hates me...
- RTA
- Same sub, same location, sealed vs. ported enclosures.
- Using REW with Digi 002 or Pro Tools?
- Frequency response cliff after 10K
- Inverting impulse responses
- DBX RTA-M mic usable ?
- Persistence pays off (new graph)
- Is REW able to import test data collected by Sencore SP295C
- Is there a way for REW to record the MATT???
- New member and RT60 with REW
- REW Cabling and Connection problem
- MIDI not working....
- Please help!!!!!
- Beginning REW, Problems
- First graph :)
- measurement tips
- first soundcard calibration attempt....thoughts?
- Distortion graph?
- My graphs - advice welcome
- Using external source and RTA
- SMS-1 and REW and FBQ2496
- Sound Card "AND" Mic preamp calibration??
- REW Basics..
- Question, some graphs
- REW connection
- Check level help
- EQ or no EQ
- Slaughter House HT REW Results
- audio input issue
- 1st rew graph
