PDA
View Full Version : Home Audio Acoustics
Pages : [1] 2 3 4 5 6 7
  1. What pink bats to use in Australia for acoustic panels?
  2. Horns and acoustic treatments
  3. Listening room: Problems/Solutions Acoustics
  4. Will diffusers work here?
  5. DIY basstraps
  6. Display case effect on reflections?
  7. I have NO BASS. Help me before I go mad!
  8. New wall and front wall
  9. Tame Mid-Room Null?
  10. flooring and carpet
  11. Do clips, GG, DD make a difference inside the room?
  12. Memory foam
  13. Room Response Calculator
  14. GIK ArtPanel Giveaway
  15. GIK ArtPanel Giveaway Qualification Thread
  16. Acoustic panels
  17. Acoutic treatment of home mixing room - before and after (graphs inside)
  18. Acoustic Panel for dedicated Home theater
  19. How To Calculate Room Gain
  20. Is bass trapping making much difference (graphs inside)? - HELP PLEASE?
  21. New project for a listening room
  22. Analysis/measurement of Room modes
  23. Isolating sound from Mechanical room
  24. Quiet Walk acoustical underlay as treatment
  25. Standing waves at 40, 400Hz
  26. Acoustic panels (GIK 242) for ceiling
  27. Front Wall Treatment Options
  28. What reflective material for basstraps?
  29. Accoustic treatment layout needs critiqued
  30. QRDude - Diffuser Calculator
  31. DIY Diffusor, treatment of first reflection
  32. 3 Sided Room...HELP
  33. Reduce decay time <30Hz
  34. Help with measurment levels.
  35. Is enough too much?
  36. Sound absorbers
  37. Should I cram more wall panels in or do the ceiling?
  38. Cinema 651 Acoustic Treatments and building acoustic panels
  39. Taming Bass Response of Front Stage
  40. Obvious discovery while making OC703 panels
  41. Bass response from 100 to 300Hz
  42. Atticat blow in insulation as Bass trap? Maybe broadband?
  43. Super-Chunk corner frame plans please
  44. Acoustic properties of horizontal wood blinds
  45. I think I screwed up before I started
  46. Help with desk/room placement
  47. Source for OC 703 and Knauf tubes in Atanta?
  48. What approach is acoustically preferred
  49. Initial subjective testing of room treatments...
  50. Help with Room sound accoustics.
  51. Thoughts on Microsuede as a Cover
  52. sound proof door
  53. Ready to make panels. What to use for backing?
  54. First Reflections
  55. Table treatments?
  56. New GIK diffusors on the way?
  57. Front Wall
  58. R38 insulation useful for front wall treatment?
  59. How to dampen front wall if I use painted on screen
  60. Very small enclosed HT and SVS speakers. Potential acoustic overkill/nightmare?
  61. Sound Treatment of Stone Fireplace?
  62. help me building a HT room
  63. Unique HT insulation situation..and question
  64. Can front speakers have built in look
  65. First Reflections
  66. Too Much Absorption?
  67. what to do with 31Hz and 38Hz room modes?
  68. FSK vs AP Facing
  69. Advice on treating early reflections
  70. Ducting for Home Theaters
  71. First attempt at DIY 703 panels + REW results
  72. pretty big dip, can not move IB sub
  73. speaker setup
  74. Optimal Panel Height
  75. Superchunk Symmetry
