Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater System Recommendations
Before buying any HTIB or Bose cube type systems read this
Discuss Before buying any HTIB or Bose cube type systems read this in the Home Theater | Audio and Video forum; Before buying any HTIB or Bose cube type systems read this This post is for people who are just starting out and are looking for an inexpensive setup for Home theater. ...
Views: 3776 - Replies: 24
Old 09-30-08, 03:18 PM   #1
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is online now
I have recently seen allot of mis-information being handed out from sales people about the quality of HTIB (Home Theater In a Box) systems and wanted to set some facts out in front of you so that you can be properly informed.
First of all this is not going to be a bash Bose or any other company thread so please keep it respectable and informative. But for some really good hard information as to why you should not buy Bose read This.
One of the biggest issues with these so called HTIB systems is the upgadeability, They usually have integrated components and strange hookup connections that make it nearly impossible to replace one piece if it fails. Also if it includes a DVD or BluRay player and they fail your stuck and cant replace it without starting from scratch in most cases. Onkyo and Yamaha have some decent systems that are simply normal receivers and speakers that can be replaced if necessary as budget allows and is a far better way to go if you must go with a HTIB system. None of there lower priced systems offer what I would call good quality. You would need to spend about $700 to get into what I call satisfactory.
HTIB systems tend to be underpowered and in medium to large rooms they lack the power to fill the space and are usually unable to allow for connection of HDMI directly to the receiver needed for all the new uncompressed audio formats coming out.
Ok, now we get into the more technical side of things:
Why should I not get a HTIB system or a system like Bose you ask besides the above mentioned?
Well for one they are all built with small speakers all 5 or 7 speakers including the sub are smaller then what should be used. The drivers in the sattalite speakers are too small to produce high volume levels known as Decibels (db's). A standard db reading of movies is generally no less than 85db this is loud enough to make you feel that the movie is surrounding you. Almost all systems in this group simply can not reach this level safely and will distort. Put simply, if the speaker drivers are smaller than 6" across and or the cabinet is smaller then a spray paint can then don't expect much form them no matter what the specifications say.
The other problem is speaker design, a small speaker physically can not reproduce the lower frequencies needed. A so called full range speaker will have a frequency response from around 45Hz (low) to 20,000Hz (high) the cube or sattalite speakers only go as low as 300Hz at best and that leaves a big hole where there is simply no sounds in that range from 300 down to where the so called sub woofer picks it up at around 140Hz. For example a nice full range speaker will sometimes have three or more drivers, a tweeter that reproduces the highs, a midrange driver and a low driver. buying one of theses systems would be like taking out the low driver and then still using the rest. You end up with a whole lot of the sound missing.
This is where some companies fool you as they will then build a so called sub that has the ability to reproduce those missing frequencies but what they don't tell you is that they simply do not reach high enough and you still end up with a hole in your sound field. The other big issue and huge design flaw is that the so called sub woofer that comes with theses systems is far to small to make enough of an impact with that sort of frequency range and never go below 40Hz which is where most real subs are just starting to work and make an impact where it counts. A true subwoofer goes no higher than about 120Hz and if they are good will go as low as 10Hz but most start to roll off at about 25Hz. These frequencies are necessary for movies as things like thunder, a freight train going by or a Harley Davidson motorcycle driving by are heard or I should say felt.
If you do want to stay small get yourself some good bookshelf speakers that have a good solid wood cabinet not plastic and get a good subwoofer from a reputable company. And if you remember that cheep speakers give you cheep sound then your off to a good start.
What I am saying is if you must go with a HTIB system do not spend the money on Bose as they are far to over priced and do not preform as they say and are very over hyped. For around $1000 you can get into a great system that is far better and wont need upgrading right away.
Save some money before buying or buy a receiver first and use some old speakers you have around the house until you can afford to buy new. Another option is to buy used equipment and there are lots of ways to go about this that I wont go into here.
Have a look at this comparison done by another Shack member explaining the quality difference between decent speakers and the HTIB type speakers that you will get with most HTIB systems.
I hope this helps inform some of you who are in this situation and keeps you from making a mistake that will be regretted down the road.
If your insistent on getting into a complete system now and want a HTIB type of system here is two that I recommend both by Onkyo.
The Onkyo HT-S5100's is a good starter system, has real wood speaker cabinats, a 10" down firing subwoofer and even Audyssey 2EQ and an iPod dock. I would prefer if people would go with there top of the line system the 9100THX system its THX certified and has 3HDMI inputs, and has a fantastic receiver for the price (around $900) its going to be tough to beat. The Shack store doesn't have it at the time of posting this information. Amazon has it
Amazon Amazon
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 09-30-08, 04:20 PM   #2
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: Before buying any HTIB or Bose cube type systems read this
Plain and simple:
1. Check that the HTIB components (speakers, DVD, receiver, etc.) can be upgraded without changing everything.
2. Look for frequency response of the system. Speakers need to reach at least to 70Hz/80Hz (lower is better).
3. Search for reviews, and ask, ask, ask a lot of questions
4. Read this thread comparing a regular speaker to a htib speaker
Old 10-01-08, 01:38 AM   #3
Alias: thxgoon
thxgoon's Avatar
User: #6924
  thxgoon is offline
Also don't be mislead by the power ratings they display. Most manufacturers will label the 'total output' power of the system which is a number that cannot be achieved. 2,000 watts for $200? Uh uh. Even if it could, do you really think a 3" paper cone woofer can take that power?
Good advice Tony! Do some research, don't be afraid to piece together a system on your own. With help (here or at the store) a better system for your money can be built that can be enjoyed for a long time.
Old 11-02-08, 08:07 PM   #4
Alias: Boo
Loc: Leavenworth, KS
User: #28034
Since: Nov 2008
  nobletime is offline
Hi, thanks for the great info.
Would you consider helping me put together a system in the $1000.00 range? I am overwhelmed by the number of threads here and not real knowledgeable on this stuff at all.
Other than that.......this is for a 12'x24' room with a vaulted ceiling of 22' high that I just built. I don't want to spend tons of $ on the system because I have a much larger area upstairs that will someday have a projection tv and I will want something better up there.
For now........I just want a nice system and considering the wife and I are used to watching a 15" color tv in the bedroom our new 50" sanyo and a cheap sound system will be a whole new world for us.
Also......I do have the ability to make cabinets and such if I were able to save $ but would prefer to save that for the upstairs. There's a walkway in the middle of the current room that is about 9' high. One time I had my portable boom box on top of it and my wife walked in and was confused where the sound was coming from as she couldn't see it so perhaps this room would be good? Might experment with locations I guess.
I apologize perhaps this thread isn't one to ask questions but I need to get going on this and don't want to get lost or a huge headache trying to figure it out on my own. Thanks for your consideration, Rob.
Old 11-02-08, 08:11 PM   #5
Alias: Boo
User: #28034
Since: Nov 2008
nobletime wrote: View Post
I'd also like to add that the walkway goes over the top of the couch that will be sitting at, I do have the ability to cut in speakers above it if I have to but then again don't know if that would be an ideal place or not or could place speakers on the walkway above. Basically I would be able to do a little custom work if I have to but since I didn't forsee any of this I prefer to look ahead before I start the main room upstairs. Probably just prebuilt system would be best but im open to suggestions.
Old 11-02-08, 08:32 PM   #6
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Sure, I can help you.
For $1000 your still a bit limited if your needing to get speakers, a receiver and DVD player. But I will list soem things at the bottom of the post.
You should be fine .
For an all in one system minus the DVD player this Onkyo system is just under your budget and has everything you need for your room. It has good speakers and a fairly feature rich receiver (sadly no HDMI inputs) and a subwoofer.
You can then look at getting a BluRay DVD player for about $250 that will also play regular DVDs. Of course this still leaves out a display Was that included in the $1000 budget?
Another option is the Onkyo 5100 its a fair bit cheaper and offers almost the same bang for buck and includes HDMI inputs but less power and a smaller sub but again would do the job. Your room size is fairly large so expecting the relatively small speakers to fill the space with what is known as refference level will be near impossible but its within your budget and will work.
You mentioned going with in ceiling or in wall speakers, this is also not a wise idea as you dont get good imaging form these speakers and unless you spend at least twice as much on them compared to what "bookshelf" speakers will do for quality you will not be happy.
Home theater:
Two Channel system:
My Webpage
Old 11-03-08, 06:41 AM   #7
Alias: Boo
User: #28034
Since: Nov 2008
tonyvdb wrote: View Post
Thanks for all the great info! That greatly simplifies things. I like and will most likely buy soon the first option you listed. I already have a tv, not the worlds greatest by far, a 50" sanyo. Considering we've been watching a small tv for the last few years while i've been building this will be a big upgrade for us. This system you recomended looks a lot more substantial than anything i've seen at the local store lol. I'm sure we'll be happy with it.
Old 11-03-08, 08:33 PM   #8
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
I'm glad I could help. Are you planing to get a BluRay player any time soon?
Home theater:
Two Channel system:
My Webpage
Old 11-03-08, 08:36 PM   #9
Alias: Boo
User: #28034
Since: Nov 2008
I have noticed prices here are significantly better than available locally, im glad I found this site!
Old 11-03-08, 08:44 PM   #10
Alias: Boo
User: #28034
Since: Nov 2008
Yes. Truthfully I don't even know what BluRay is lol! I assume this plays standard dvd's? If you wouldn't mind posting a link to something in the $250 range that you like that would help out, I really don't know much at all about this stuff. Showed the wife the system you recomended, she said buy it so it looks like we'll be getting it as soon as I get the BluRay figured out. Thanks again, this has saved me a lot of time and hassle I really appreciate it.
Old 11-03-08, 08:56 PM   #11
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
If your looking at getting a BluRay player you may want to get the second system I mentioned as BluRay uses a special connector for audio and video called High Definition Media interface (HDMI) BluRay is a new DVD format, the movie is recorded in High Definition and looks really good compared to standard DVD. The HDMI connector is 100% digital and includes the audio all in one cable. The BluRay player will still also play your regular DVDs.
The Panasonic BD35 is one of the better ones available or the Samsung BD-P1500 but the standard DVD playback is not quite as good.
Home theater:
Two Channel system:
My Webpage
Old 11-03-08, 09:34 PM   #12
Alias: Boo
User: #28034
Since: Nov 2008
Yes I overlooked the HDMI part. Do you think there will be a huge difference in sound with the smaller system? We don't need anything stellar and the smaller system still looks pretty good to me.
Old 11-04-08, 06:53 AM   #13
Alias: Boo
User: #28034
Since: Nov 2008
Probably will order this stuff when I get home from work today. I don't even have the furniture moved into the room yet I am waiting for the floor coat to cure. Tv's still in box, kinda hoping I don't end up needing a bunch of extra wires and such, man those give me a headache lol. Thanks again.
Old 11-04-08, 10:23 AM   #14
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Probably not, Video wise you will see a difference but the speakers are not really large enough to really hear the difference between using just the standard Dolby digital or DTS audio that is included on BluRay DVDs. HDMI allows a person to use the newer audio formats called DTS Master Audio and Dolby TruHD as these two formats are uncompressed and have a better dynamic range that both systems mentioned above wont really have the size to reproduce.
Home theater:
Two Channel system:
My Webpage
Old 11-04-08, 11:56 AM   #15
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Congratulations ... and Welcome to the Hobby
I completely agree with what Tony suggested ...as far as cables go, if you just connect the BluRay, Onkyo 5100 and TV you'll need "two HDMI cables", one from BluRay to receiver, and another from receiver to TV ...
If you need to buy cables, this place has the better prices www.monoprice.com ... and as far as connections goes; if you have any difficulties ... feel free to post and somebody will help you with the steps ...
Old 11-04-08, 12:09 PM   #16
Alias: Zip
MatrixDweller's Avatar
Loc: Canada
User: #10408
Since: Jul 2007
  MatrixDweller is offline
One of the things I see a lot on HTIB systems is that their wattage rating is fairly high. They'll have in their specs that it is a 900W system or even a 2000W system when you include the subwoofer. If you look at the spec in more detail you'll see that the receiver might be rated for 140W per channel at 10% THD and only at 1000Hz (not 20-20,000Hz). At 10% THD the sound would be just horrible and there would be so much clipping that the speakers could get damaged. Even at around 1% THD the system would start to sound pretty bad. If you were to rate the wattage of the receiver at a more respectable 0.1% THD it would probably only be putting out a 10th of the power.
Ask the average Joe what the number one quality of a home theater receiver, or stereo system for that matter, that dictates it's quality and they will say wattage. Bottom line is that the manufacturer is deliberately misleading an uneducated consumer to think that the speaker system is better than it actually is. They aren't outright lying about it, they are just banking on your ignorance.
Old 11-04-08, 12:45 PM   #17
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
MatrixDweller wrote: View Post
This is why I like the Onkyo 5100's price point. Its a good starter system, has real wood speaker cabinats, a 10" down firing subwoofer and even Audyssey 2EQ and an iPod dock. I would prefer if people would go with there top of the line system the 9100THX system but its over $800 and the shack store doesn't have it. Most people that are just starting out dont want to spend that kind of cash and want an entire system right away.
I have edited my first post to reflect this information.
Home theater:
Two Channel system:
My Webpage
Old 11-04-08, 01:17 PM   #18
Alias: Zip
Loc: Canada
User: #10408
Since: Jul 2007
The 9100THX system almost makes me want to sell everything...well almost. If I had to buy a HTIB it would be that one. A great receiver and half decent speakers. I might buy one for my living room if it would pass muster with the finance mistress.
Old 11-04-08, 07:29 PM   #19
Alias: Boo
User: #28034
Since: Nov 2008
I decided to just go with the 5100 and the Samsung player. Mainly because I am in the process of building the upstairs entertainment area and this room will probably not be used a whole lot when it's done so ill save the $ for upstairs.
One last question for now...........Am I going to need extra cables and what kind? I'd just assume order them and get it out of the way. Thanks for everyones help/ suggestions.
Old 11-04-08, 07:47 PM   #20
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
What will you be connecting???
If is just TV, BluRay player and AVR (receiver) you need two hdmi cables (one from player to AVR, and another from AVR to TV
Old 11-05-08, 10:20 AM   #21
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
salvasol wrote: View Post
you need two HDMI cables (one from player to AVR, and another from AVR to TV
And dont buy the expensive Monster or other over priced cables as there is no difference in quality other than paying for the name. This one will work just fine.
Home theater:
Two Channel system:
My Webpage
Old 02-18-09, 07:51 AM   #22
Alias: MasterGuns
Loc: Okinawa
User: #34190
Since: Feb 2009
  MasterGuns is offline
Good advice by all on equipment and cables. One last thing you are going to want to take into consideration is speaker wire. If you have a 24 foot room you could potentially have between 30-50 ft runs of wire (in order to hide it.)
Don't get caught in the trap of buying the expensive wire.I recommend that you go to Your friendly neighborhood bigbox hardware store, and ask for a reel of 14-16 gauge zip wire (14 gauge for over 30 ft). You can pick the color that matches your decor best. If you are smart you will make sure you're runs are long enough for your future home theater and you can use the same wire.
Old 04-26-09, 01:59 PM   #23
Silver Supporter
Alias: Lester
waldo563's Avatar
Loc: Longmont, CO
User: #36847
Since: Apr 2009
  waldo563 is offline
I wish I had read this before I made the mistake of buying a Bose Acoustimass system. I'm not saying that the Bose systems may not be right for some people who will never want to upgrade anything and may not care about room filling sound. Unfortunately, I only considered the proprietary speaker hookup after the fact and was constantly straining to hear the dialog on the center channel (which of course is identical to all of the other speakers).
Old 10-07-09, 12:09 AM   #24
New Member
Alias: Jeff
Loc: Edmonton, AB, Canada
User: #43011
Since: Oct 2009
  Jeff is offline
I was originally going to go with the Bose system but after researching for a while, I was able to put together a very respectable system and save myself thousands of dollars.
I was trying to make a clean install with a roll up screen, no speakers on the floor and all components hidden. Everything was a success, except I was unable to hide the Sub.
My system is as follows:
135" Motorized Tension Screen
Panasonic PT-AE3000
Pioneer SC-07 Receiver
Samsung BDP1590
Belkin Power Conditioner
7 Speaker in ceiling system
12 Inch Sub
And All Cables
For half of what I was being quoted for the out of the box systems, with WAY more flexibity and expandability.
Both myself and wife are extremely happy with the system. It is good quality, looks and sounds good, kids can use it, everthing is hidden out of the way when the hockey sticks are out and our room is not overpowered when sytem is not in use.
It definately pays to do your homework and shop around. I owe alot of my success and knowledge to sites like this.
Old 10-29-09, 12:50 PM   #25
Alias: Sam Ash
User: #41011
Since: Aug 2009
  Sam Ash is offline
Exclamation Re: Before buying any HTIB or Bose cube type systems read this
MasterGuns wrote: View Post
You are so right about the cables / wire. Unfortunately, I learnt that the hard way. If I knew this earlier, I could have put the extra money where it really matters (amp, speakers, projector).
« Home Theater Shack > Home Theater | Audio and Video > Home Theater System Recommendations »
befor, bose, buying, htib, lifestyle, read, systems, type
