Sorry if this post seems ridiculous but I am new to this dedicated HT thing. Up until now I have just dealt with a 55" LCD TV and soundbar/sub combo. I never really delved much into the world of HT.
So that being said I have been looking into what will go into my new room. The dimensions are roughly 21' deep x 15' wide x 9' high.
I am looking at AVR's in the $1000 range (Denon AVR-x3300, Marantz SR5011)
So is there a rule of thumb for what to spend on speakers? Should you set aside 2 times the cost of the receiver or something like that. I have been looking online at speakers and it makes my head hurt there is so much out there and the costs are all over the board. I know I want a 7.2 system but not sure what I should be looking for. I travel a lot for work so I don't have tons of time to go listen to systems somewhere. So i am defaulting to the community that has put the work into finding things that work.
I don't really want to spend much more than 8k for the AVR, speakers and sub. On that note is it better to go with an AVR or get separate components?
Thanks in advance for the help I will be checking back often as I can while I travel. I am hoping to get this whole thing wrapped up by end of year.
Generally you do want to spend more money on speakers than anything else. Given that's the speakers are ultimately the item that output the sound into your room they need to be decent. That said though if you have other items in the chain that are not up to the task it won't matter how good the speakers are if you have a weak link some where else in the chain will be the deciding factor "garbage in garbage out"
A subwoofer will be something you don't want to skimp on as the bigger the better does apply here. Where soround speakers would be an area that can be cut back on in a pinch.
As far as your going with separates over a receiver that is not really nessisary other than to get an amp for your main left and right channels and let the receiver run the rest. A receiver that comes with pre outs is a must in order to accomplish this and none of the entry or mid level receivers have them. Look for a receiver that has some weight to it as this is usually a good indication it has a beefier amplification section. (If less than 30lbs don't even go there unless it uses a class D amp section)
Tony, Are you saying under 30 it is no good? I took the plunge on the X4200 that is roughly 26 pounds and not a D amp. Most of todays middle line receivers are not as hefty like they used to be. Does this mean I should send it back because my 805 weights almost twice the amount?
This is what worries me about todays receivers you sacrifice amp for more features.
ALSO my apologies for the hijack here just had to ask
I don't know of any established rules for spec'ing out a system, so I think you can just go with what works for you. In the end that's the only thing that really matters.
An 8K budget will get you a very nice setup. It also gives you a lot of flexibility. Your room is just over 2800 ft^3, so it's about midsize. That means you won't need a lot to get the full HT experience.
More information will help people give you relevant suggestions though. Thing like what are your viewing habits, do you enjoy cranking it up or are you more inclined to leave the volume lower? Do you prefer a sound that's bright and air, or is that shrill for you and you'd rather have something with less presence? Are there size restrictions that would take tower speakers off the table? What about WAF (Wife Acceptance Factor), any restrictions from that angle? What about finish options? Do you tend more toward gloss paint, wood grain veneers, something else perhaps?
I would say I am somewhat of a syfy/comic book moive geek.(Favorite movies are the LOTR trilogy, just about anything Marvel and of course Star Trek, Star Wars (not so much episode 1 and 2) So that is what I will be watching 90% of the time. After years of being around Gas Turbines I would say I listen to things louder than most. (That is also a problem because I am sure I have lost some hearing) I also enjoy spending a some time with my XBOX ONE on first person shooters.
As for the WAF she would prefer in-wall or in-ceiling but she is not objected to towers as long as they don't look "home built". (no offense to the speaker builders out there her words not mine) I would say no gloss as I would think that would reflect light (I may be way off there)
No planning on listening to music much if at all with the system. (That will be the next set up downstairs)
8k is a great budget! You can get a serious system with that amount. Speakers for HT don't require the level of sophistication that a 2 channel rig requires. Most of us use our system for both, so we bought for that.
You can save some money with http://www.accessories4less.com/. They offer deeply discounted factory refurbs with the option of an additional warranty that lasts longer than a new model comes with. Just remember, this is an addictive hobby. If you plan carefully you can have an exceptional theater that you'll be proud for you all your friends to enjoy!
Welcome to the forum! Feel free to ask us anything at all...and there are no dumb, newbie questions. We were all newbies at one point!
Syfy flicks tend to have pretty good soundtracks, with a lot of deep bass in parts (I too am a LOTR fan, so I know those very well, but the Star Wars/Trek movies are less to my liking). For speakers check out KEF, Axiom Audio, PSB, Salk Sound and Monitor Audio. They each have a bunch of different series, so they're bound to have something that you and the misses can agree upon. For subwoofers look at Rythmik, HSU Research, Power Sound Audio and Seaton Sound.
If you want to get something customized Salk and Seaton are two of the best for that. They can provide almost any finish your heart desires, and their products are top notch when it comes to sound quality as well.
Thanks for the advice and list of things for me to check out. It appears I have some homework to do. One question though I have a friend of mine that has some Bowers and Wilkins speakers in his house. (Not a dedicated HT but a multi use game room) I was talking to him tonight and he told me to look into them. I don't much mentioned about them on this site. Is that brand good for HT or are they mostly a music speaker?
I have also heard some rules back in the day but things are different now. With people being more educated (both buyers and makers), sound quality has really gone up in the lower price points. Buyer also know the cost/performance curve can work against you if you are not able to place your speakers correctly (mostly for music). The thing to keep in mind is that the speaker we talk about here and recommend will sound great and most people will be happy with them for years to come weather you spent $1000 or $8000.
The AVR you have picked are great. For speakers I would look at ELAC (lower budget) or Chane ARX (mid Budget). The Sub is really where you are going to spend your money. Get it right the first time and get two. We do not see people buying an AVR that wish they got a bigger/better model as you can just add an amp to the front sound stage. We do not see people buying speakers that wish they got a bigger/better model as you will love and get use to any quality speaker (as long as it can play to your SPL level in your room). We do see people all the time wishing they got a bigger/better sub or that wish they got two all the time. And this is most people not just bass heads.
I don't have any pictures as the house is currently being built. Will be done in about 4 months.
AVR is all you will need for now...
I have to say, I am very impressed with B&W speakers. A great British speaker manufacturer with a long list of speaker design patents and technology firsts. If I had $40,000 I'd buy the 800 Diamond pair.., ah , but then I'd have to upgrade my cables and invest in seperate electronics etc etc. Luckily though some of the technology does trickle down into the more affordable HT/Music speakers.
In the past I have read reviews describing speakers as being better at music repro or preferred for movie repro but for the most part these days good speakers will reproduce either/or sound program input IMHO and that it is the speaker array and numbers of speakers and speaker placement and matched electronics etc etc that have the greatest impact.
About your choice of Denon AVR - I recently bought the Denon AVR X4200 and I'm very happy with sound thru my 5.1 B&W 303's and Focal sub. I upgraded to the newer Denon receiver because of its Dolby Atmos electronics. However the next day I learned Denon's newer AVR X6200 came with the new and improved DTS-X surround sound programming. Seems to me I read somewhere I can buy the DTS-X module to update the X4200..., oh well. I'm not even sure how many new movie releases are using the DTS-X programming format in any case until I build new front speakers I'm only using 5.1 speakers...
The only other thought I would offer - I believe 120 watts per channel is plenty of power for most speakers but for some of the larger more demanding three-way designs etc I would want 150-200watts this removes all doubt especially with most newer solid-state electronics, 150watts get the job done. Its not very often you find newer speakers with efficiency SPL ratings much below 90db and with 150watts sound has a consistently effortless quality at any volume.
Oh yeah, I just want to add - the ELAC speakers mentioned above are recently reviewed here at HTS. Also, Stereophile mag's recent review of ELAC speakers made many impressive comments about the ELAC B6 review pair and a CEShow pair setup. It seems everyone who listened/heard them stopped for a little critical listening and sounded very happy they did.
Just a few more to consider..., hope your enjoying the process
Oh, FYI - the actual "Rule of Thumb" was an unwritten law stating a parent, husband, etc could not cut a stick bigger around than his thumb to discipline his children/orphan, wife, slave or occupants of early psychiatric facilities etc etc. Unfortunately it wasn't until the 1940's that states began to write laws protecting children from parental abuse and not until the 60's states wrote laws specifically protecting women from spousal abuse. Even after women won the right to vote in 1920 it still took 40 years to convince state gov lawmakers physical abuse was not the best response/solution to controversy. To this day, around the world, police and the courts are reluctant to interfere "family matters."
Communication and education is the answer - somehow education is still not the popular answer.
4 or 5 small paragraphs from a drive-by at a show are not a review, more like a quick mention. Hopefully we can arrange to get a pair though, and that way one of us can actually do a review.
I definitely agree that you should make speakers a priority. But if you are going to use self-powered subs, you can probably afford to scrimp on the AVR. I have been very happy with a Denon AVR-S510BT at $229 (70w/ch into 8 ohms) that automatically adjusts the output to your acoustic environment. I found that 100w/ch was more than adequate to drive my previous room, which was somewhat larger than yours. Also, bear in mind that the most important factor determining how well speakers sound is the room you put them in. So spend some time on acoustical design. This site will afford plenty of suggestions.
OK, OK a few passing thoughts in retrospect. A brief impression. A snapshot observation with quick assessment, like my first comment. Yeah I don't think he lived with the speakers long enough to allow for a brief break-in and with no meters/measurements..., but the ELAC name has been mentioned on more than one occasion along with some interesting impressions of musical character. I hope you do get a pair for review. Stereophile reviewed the B6's I believe and the reviewer made references to the smaller B4 or B5 he had listened to briefly. Might be helpful to review one of the other smaller speaker pairs for actual comp with Stereophile' B6 review although for $50 more the B6 is probable the one we are all more interested in learning about.
I was going to suggest Chase Home Theater for the subwoofers but none of his web pages would load this morning. Do you know, has Chas ended this business venture. I don't know of anyone more knowledgeable about engineering and building high quality speakers at amazingly affordable prices.
Craig Chase closed his operation and merged with The Audio Insider several years ago. That merger was dissolved at least a year ago, and at that time Craig decided to get out of the audio business entirely.
Related Threads
742.3K posts
170.9K members
Since 2006
