I built my home and at the time of building could not afford an audio system to save my life. So, I just ran 14 gauge CL3 wire in the attic to desired speaker locations for ceiling mount, and also ran to and from wires to 3 designated in-wall volume control locations for each bathroom & the main living area. A couple speakers are just home runs to the speaker. Hindsight is 20-20, and for the extra work to make all speakers their own volume control would have been negligible. At the time I figured "Hey the amp will have each independent zone control so I don't need to spend the extra $ for wire and the future knob.
Anywho, I am now looking into a system. At least something I can start saving up for. I have 6 speaker locations total, 1 will be outdoor on the deck when the deck is...built. :innocent:
I'd like to have a 6 zone system at least with independent volume adjustment for each zone. I confused myself a little with the livingroom/kitchen area because if I remember right, I ran independent wires to each speaker to the desired volume knob...but I think I could have just ran one feed to the knob and then run each feed to the speaker. This would mean maybe a 5 zone would work, but I assume they come in even numbers. I don't know where to start on brand and price range. I want a good system that lasts me many years, and has enough volume that I can really jam out to. I know a lot of that depends on my speakers, but I want the amp/receiver (not sure the proper term in this case) to push a decent amount of RMS Watts per zone and not just a small amount shared across all zones.
Thanks for input. I'll answer anything I can to help.
Does Russound still produce new units? I'll have to look at the pricing. The monoprice looks nice, but it seems with only 6 reviews it has 2.5 stars out of 5. Seems a bit shabby for such a price if it's not very good.
That's a decent price. Question though, since I don't have Left and Right 'channels'...what is the 12 channel going to play out to be like? See, I ran wire for 1 speaker centrally located in each room. Office, Master Bath, Main Bath, Living Room, Kitchen, and Patio. Do I just run the set of wire to 1 side (L or R) ?
Might want to check out Home Theater Direct – they specialize in whole-house audio.
That said, the commercial audio world long ago figured out the best and cheapest way to accomplish multiple ceiling speaker installation – 70 volt systems.
I will look there, too. I have heard of the 70 volt system, but the volume is normally adjusted on that transformer that goes with the speaker instead of a volume knob. I'm afraid the knob would impede with the transformer.
By your description it looks like you have three zone control locations, one at each volume control. However, you have two zones for each of those control locations. IF that is the case you will need to get a control similar to this https://www.amazon.com/PyleHome-PVCD15-Speaker-Independent-Control/dp/B007A99ICA
However this one would only work if you are running a mono signal to each location.
I can't fathom what I was thinking back when I ran wire. I had just helped install a 70 volt system for a family member where we ran 2 strand wire. I should have definitely ran 4 strand wire, shouldn't I? One speaker in each location is fine, but it's probably a lot better if it's a 'Stereo' speaker with dual input on the back, requiring 4 wires instead of the 2 I ran! :doh::doh::hissyfit:
If sound volume is an issue (decibels) you should look more at the size of the speaker then that of the amp. You may find it counterintuitive but a 100watt amp pushing a 5" speaker may not end up sounding as good as an 8" with a 40 watt amp. Also how securely the speaker is mounted may make a difference.
Since you have not pre planned the size of speaker you will be installing I take it you did not pre install any type of bracket for you speakers and the plan is to suspend them from the ceiling drywall. Hopefully you don't have loose fill insulation or your hole cutting will make a mess... Anyway, if you are mounting the speaker on the drywall (i.e. some type of tab flips out when you tighten a screw on the front of the speaker) I will suggests that if its not already there get some foam tape for around the edge that sits against the drywall, this will help with the woofer vibrating the drywall.
I just ran wire to a center location between my trusses so any speaker size could be added. I taped the wire to my fiberglass insulation batting, and measured before hanging the ceiling 5/8" rock. The idea is to come in now, or when ready, measure to that taped wire location, cut a small diameter hole to find the wire, and then adjust the hole to the size I want for a speaker. I will then more than likely cut out some of the fiberglass insulation to fit a speaker without the speaker compressing into the fiberglass, since the kraft paper is facing down, it would dome my insulation causing a less R value in the whole general area since the insulation would not lay flat anymore.
I have installed speakers before that only required metal tabs to be bent over once the speaker is installed from the bottom, and screws through the rock to mount it. Yes, I plan on the 5/8" rock supporting my speaker. The foam is a good idea, I will probably look into 1/4" thick maybe 3/8" thick? If I got the wild hair......to blow an attic door in where I framed out for one, as I have sealed the attic for the time being since I do not need any access to it....then I may decide to then run 4 conductor wire...maybe ... hopefully I could just tape to the old wire, and gently pull it out from all the locations...wasting that $200 worth of 2 conductor wire...lol. At the same time I'd probably run some romex for desired can lights that did not fit the budget Besides the horrible positions it would take to monkey through the atttic, I know I would never get the same R-Value I currently have since I diligently poofed each piece of insulation to maximum efficiency thinking it would never have to be walked on!
You're telling me. I planned for several months, albeit alone not with outside sources giving input. My biggest crutch was not willing to go over budget on my build, and not realizing I would *really* want those extra things later on...costing more headache and money later.
Ah, I didn't look into that very far. And true, I guess I was thinking more along the lines of 20 rms vs 60 rms, but I'm sure it's not too noticeable either. More so than 20 to 40, though. :T
Related Threads
742.3K posts
170.9K members
Since 2006
