Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater System Recommendations
Help me decide on first surround system
Discuss Help me decide on first surround system in the Home Theater | Audio and Video forum; Help me decide on first surround system Goodmorning, This is my first post and have come here in hops of receiving some solid advice on which system ...
Views: 983 - Replies: 40
Old 02-16-09, 05:34 AM   #1
Alias: stiflerMT
User: #34067
Since: Feb 2009
  stifler is offline
Goodmorning,
This is my first post and have come here in hops of receiving some solid advice on which system to get. First tings first some background info - so that you can understand my needs. I have recently purchased a plasma screen which I am planning to compliment with glorious sound. The surround receiver will be connected to my satellite dish, PS3, 360 using 2 optical connectors for the consoles and RCA cables for the dish. The setup will be used for Blue-ray, gaming and DVDs
Based on my research I have narrowed down my selection to two possible systems:
  • Sony Home Cinema DVD System DAV-DZ830W
  • Sony Home Cinema System HT-DDWG800
As the 830W costs 450 euro more than the second option would the investment be worth the money? As in will I get good quality HD sound from above systems and which would you recommend.
Thanks in advance
Old 02-16-09, 10:54 AM   #2
Alias: Jay
jackfish's Avatar
Loc: Western Wisconsin
User: #5100
Since: Dec 2006
  jackfish is offline
Re: Help me decide on first surround system
I find the Sony Home Cinema DVD System DAV-DZ830W for 557 euro in closeout. It is a Home Theater in a Box that cannot stand up to a well thought out component system. Think about saving up more and then asking about components once you have your ultimate budget settled. Good Luck!
Old 02-16-09, 11:48 AM   #3
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Hello, Welcome to the Shack!
First of all have a look at this post, Home Theater in a Box systems do not stand up well to the dynamics of todays movies.
Sony is not well known for good quality receivers or speakers, If you must go with a HTIB system Onkyo makes some of the better ones.
As Jay already said if you could give us a budget that would help as we may be able to find something better.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 02-16-09, 01:46 PM   #4
Alias: stiflerMT
User: #34067
Since: Feb 2009
  stifler is offline
mmm lets say max budget 1000 euro is it possible to build a decent DIY system? Id rather spend a bit more and get good value for money then go cheep and regret it. Also anyone know of some good online retailers that ship worldwide as amazon doesnt ship to my country large parcels unfortunately.
Old 02-16-09, 01:49 PM   #5
Alias: stiflerMT
User: #34067
Since: Feb 2009
  stifler is offline
buget is expandable up to 1500 euro
Old 02-16-09, 02:38 PM   #6
Alias: stiflerMT
User: #34067
Since: Feb 2009
  stifler is offline
I decided to go the custom build way, now im at a dilemma as to which receiver to get I was considering the Onkyo TX-SR576 which is priced at 350 euro which sounds reasonable to me. Am I right in the assumption that I do not need a receiver to decode HD signals as the PS3 can output the sound in linear PCM ? Or must I invest in a HD decoder? Is the extar price for the HD worth it ? sorry im new to surround
Old 02-16-09, 02:58 PM   #7
Alias: stiflerMT
User: #34067
Since: Feb 2009
  stifler is offline
What o you guys think of the bose Acoustimass 6 speakers (5.1) for now then extended to 7.1 later
Old 02-16-09, 03:40 PM   #8
Alias: stiflerMT
User: #34067
Since: Feb 2009
  stifler is offline
Just read the bose reviews on this site anyone have any suggestion for better speakers
Old 02-16-09, 03:54 PM   #9
Alias: stiflerMT
User: #34067
Since: Feb 2009
  stifler is offline
opinions on denon SYS-76HT speakers to compliment AV reciever
Old 02-16-09, 03:57 PM   #10
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
stifler wrote: View Post
I think you're okay with the 576 (it has HDMI connectors need it to get HD audio from PS3); the 576 can decode DolbyDigital Plus, so maybe you'll need to decode other formats on PS3 ...but you'll be fine.
Good luck with your project.
Old 02-16-09, 04:01 PM   #11
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
I think it will be a better option to get an Onkyo system (6100, 7100, etc.), their speakers have a better frequency response than most HTIB.
What other brands can you get where you live??? ...JBL, Polk, etc.
Old 02-16-09, 04:09 PM   #12
Alias: stiflerMT
User: #34067
Since: Feb 2009
  stifler is offline
Il phone a couple of retailers in the morning and post the outcome.
Old 02-16-09, 04:21 PM   #13
Alias: Jay
jackfish's Avatar
User: #5100
Since: Dec 2006
  jackfish is offline
It is likely you can get what you need in Europe. What country and city are you in?
My recommendation for buying something unheard would be the underrated Infinity Primus line. Person after person, review after review places these speakers squarely in the "Best for the Money" class. The tower, bookshelf and center speakers listed below all use the same drivers and are extremely well matched.
Infinity Primus P252 towers - $295/pair
Infinity Primus P152 bookshelves - $155/pair
Infinity Primus PC250 center - $134
Infinity PS210 subwoofer - $295
TOTAL - $879 or €688
International shipping available.
If you need 7.1 just add another pair of P152s.
Matched with the Onkyo TX-SR576 for €350 and you are in for under €1500 with shipping.
Old 02-17-09, 12:25 AM   #14
Alias: stiflerMT
User: #34067
Since: Feb 2009
  stifler is offline
Im from Malta within the EU, what retailer sells the above speakers?
Old 02-17-09, 12:50 AM   #15
Alias: stiflerMT
User: #34067
Since: Feb 2009
  stifler is offline
Is placing the center speaker behind the TV a issue with surround systems as the way the room is furnished this is the only option (it cant rest on the TV) as its a plasma hence paper thin in construction
Old 02-17-09, 01:06 AM   #16
Bronze Supporter
Alias: Kevin
nathometheatre's Avatar
Loc: Garland Texas
User: #34122
Since: Feb 2009
  nathometheatre is offline
I have to agree with "Jackfish" in recommending the Infinity Primus speakers. My first system was the Infinity Interlude speakers, and at that time I had a Denon avr-2802. If your comfortable buying on ebay or Audiogon, you could probably find a mint condition Denon avr-3802 or 03 for around $300 american dollars. This is a great starter system, and the infinity's mix well with any high current Denon receiver. This system will blow away most HTIB systems. For what it's worth, in my opinion I'd stay away from Bose no matter what the cost. Hope this helps! Good Luck!
Old 02-17-09, 10:18 AM   #17
Alias: Jay
jackfish's Avatar
User: #5100
Since: Dec 2006
  jackfish is offline
International shipping more than doubles the cost of these items. You'ld be better off buying within the EU even if the prices are a bit higher. Call these establishments and ask about the Infinity Primus line; you have the model numbers from above.
EU Infinity Home Audio dealers:
Cutajar Ltd. Birkirkara, Malta Phone +356 21441720/21445603 Fax +356 21498632 Email cutajar@vol.net.mt
Kenwood Electronics Italia S.P.A. Milano, Italia Phone +39-02 204 821 Fax +39-02 2295 16281 Email info@kenwood.it
Harman France S.A. Paris, France Phone 33-1 55 78 54 00 Fax 33-1 55 78 54 01 Email hci_contact_france@harman.com
Lyric Ae Athens, Greece Phone 30-182 10 263 Fax 30-182 19 193 Email lyric@otenet.gr
Amacom 11633 Athens, Greece Phone 210 701 5259 Email theo@amacom.nu
Amacom - Greek Showroom GALATSIOU 41 3rd Floor GR-111.41 Athens, Greece Phone 0030-210 2232621 Fax 0030-210 2232621
Media Audio Split, Croatia Phone 00-385-21-343-161 Fax 00-385-21-315-220 Email info@mediaaudio.hr
BOFEX d.o.o. Ljubljana, Slovenia Phone +386 1 309 38 22 Fax +386 1 524 54 78 Email gregor.klancnik@bigbang.si
Harman Consumer UK St. Albans, Hertfordshire UK Phone +44 1707 278100 Fax +44 1707 278129 Email info.uk@harman.com
There are over 100 dealers that handle Infinity Home Audio in Germany. "http://www.infinity.de/home/where_to_buy/international_where_to_buy.aspx" Copy the text between the quotes and paste into your browser and select Germany.
You can place your Plasma TV on top of the center channel speaker.
Old 02-18-09, 06:59 AM   #18
Alias: MasterGuns
Loc: Okinawa
User: #34190
Since: Feb 2009
  MasterGuns is offline
stifler,
There are obviously a lot of ideas out there. IMHO you have two choices.
1. stck with your current budget and get a HTIB ( I also recommend the Onkyo as I have owned several, and put them in my kids rooms when I am ready for an upgrade.)
2. Save more money and get a custom system that you will meet your needs over time. (you end up saving more in the long run) Tons of choices here. Read posts and they can give you a million ideas.
I know it is hard to wait, but you will definately notice a difference.
Best of luck to you.
Old 02-18-09, 09:11 PM   #19
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
If the TV will block or reflect the speaker audio...yes is an issue.
Can you use a shelf above/below TV??? ...Can you post a picture of your setup???
Old 02-19-09, 04:05 AM   #20
Alias: stiflerMT
User: #34067
Since: Feb 2009
  stifler is offline
Hi guys, thanks for all the posts. I have narrowed down my A/V choice to a TX-SR806 or 876 box as I have read that the 806 has some serious issues with 1080p direct feed (blue pixles etc) can someone confirm that the 876 is free of such issues and can pass a 1080p signal untouched?
Old 02-19-09, 05:00 AM   #21
Alias: stiflerMT
User: #34067
Since: Feb 2009
  stifler is offline
Anyone ever used the Mission M cube 5.1 speakers as my friend recommended them due to there small size, any opinions?
Old 02-19-09, 10:21 AM   #22
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
The 876 is fine with video, the 806 has a smaller power supply and did poorly driving a 4ohm load but for most people it is still a capable receiver I am personally happy I have the 805 rather than the 806.
Mission makes decent speakers however they are not as good as they used to be in the early 90s. That said any small cube type speaker should be avoided see here for more info on that subject.
Home theater:
Two Channel system:
My Webpage
Old 02-25-09, 10:55 AM   #23
Alias: stiflerMT
User: #34067
Since: Feb 2009
  stifler is offline
I ended up getting the NR906 A/V receiver. can someone suggest some killer speakers to do this bad boy some justice? - I was thinking the M cubes sound nice
Old 02-25-09, 12:25 PM   #24
Alias: stiflerMT
User: #34067
Since: Feb 2009
  stifler is offline
What type of connectors (speaker wire termination) does this receiver support as I want to order some quality cable from monster
Old 02-25-09, 12:33 PM   #25
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Do not waist your money on monster cables, they are no better than generic wire you can buy at the Home depot in a spool. You should buy 14awg wire for the speakers and use HDMI cables for your DVD/BluRay player and to your display again dont buy over priced cables as they make no visual or audible difference. A decent HDMI cable should cost no more than $40 for 6ft.
Home theater:
Two Channel system:
My Webpage
« Home Theater Shack > Home Theater | Audio and Video > Home Theater System Recommendations »
decide, surround, system
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
