| Home Theater System Recommendations opinions on Energy ESWV10 Subwoofer...Discuss opinions on Energy ESWV10 Subwoofer... in the Home Theater | Audio and Video forum; opinions on Energy ESWV10 Subwoofer... hello all! I just came across this deal ... its $800 reg(seen them around for $400ish), but on sale for ... |
Views: 757 - Replies: 2
| opinions on Energy ESWV10 Subwoofer... hello all! I just came across this deal... its $800 reg(seen them around for $400ish), but on sale for $299 w/free shipping! i can't find any reviews about this sub. so i guess im asking, is this a good buy compared to other subs in its price range? -any opinions would be appreciated. here are the Specifications: System Type: Bass Reflex with Rear Firing Dual Ports Frequency Response: 23Hz-120Hz +/- 3dB Amplifier Power Output: 300 Watts RMS, 1200 Watts Dynamic Woofer: 10” (25.4 cm) Woven Composite Fiberglas™ Cone with Patented Ribbed Elliptical Surround Variable Low Pass Filter: 40Hz-120Hz @ 18dB/octave Variable Phase Control: -180° to +180° Power Mode Switch: On/Auto/Off Inputs: Line In/Sub In & Speaker Level In Overall Dimensions: inches: 14 5/8 x 14 5/8 x 15 5/8 mm: 371.5 x 371.5 x 396.9 (add 2 1/16” (52.4mm) for feet) Weight: 39.7 lb / 18 kg Crossover Filter Switch: Active / Bypass Voice Coil Diameter: 2” (508 mm) Finishes: High Gloss Black Polyurethane thanks, Jimmy | ||||
| | #2 | ||||
| Re: opinions on Energy ESWV10 Subwoofer... Well, a google search reveals that Amazon has it for $400, list at $700. Same for Crutchfield, though they list at $800. I'd say that it a sale, but not quite the deal of the century. Audioholics has a thread from an owner that replaced a velodyne and was happy with the improvement: http://forums.audioholics.com/forums...ad.php?t=42488 Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #3 | ||||
| Re: opinions on Energy ESWV10 Subwoofer... For $299 its not a bad sub and it gets you something that will go fairly low however 23Hz is still a bit high for my liking. For just a bit more you can get yourself abetter SVS PB10 NSD and its frequency response is 20-100Hz Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| Bookmarks |
| Tags |
| energy, eswv10, opinions, subwoofer... |
| Thread Tools | |
