| Home Theater System Recommendations Credit on my account - which option should I get next?Discuss Credit on my account - which option should I get next? in the Home Theater | Audio and Video forum; Credit on my account - which option should I get next? OK, so the place where I bought a piece of gear has a credit coming to me! I have two ... |
Views: 257 - Replies: 8
| Credit on my account - which option should I get next? OK, so the place where I bought a piece of gear has a credit coming to me! I have two options that I am weighing, but if it looks like I need to allocate the funds elsewhere, I am open to suggestions. I am thinking of either,
Whaddya think? HT Gear: Mitsubishi 60" DLP Marantz NR1501 Polk RM6750 Polk CS1 Polk Monitor 50's 2x Acoustic Research Wireless phones Toshiba HD-A20 Xbox 360 Pro | ||||
| | #2 | ||||
| Re: Credit on my account - which option should I get next? Hello, I would probably go with the subwoofer. Velodyne makes excellent subwoofers and should make an meaningful impact to your system. Cheers, JJ | ||||
| | #3 | ||||
| Re: Credit on my account - which option should I get next? It somewhat depends on your situation. Are you happy with your current subwoofers performance? Are you happy with your current AVR's performance? If the answer is yes to either of them, can you hold on to that credit for a while longer until you find something you do need to upgrade? Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx | ||||
| | #4 | |||||
| Re: Credit on my account - which option should I get next? Quote:
HT Gear: Mitsubishi 60" DLP Marantz NR1501 Polk RM6750 Polk CS1 Polk Monitor 50's 2x Acoustic Research Wireless phones Toshiba HD-A20 Xbox 360 Pro Sony Uni-Remote | |||||
| | #5 | ||||
| Re: Credit on my account - which option should I get next? Then my suggestion would to go with a new AVR for sure. I've also owned a Polk sub, the PSW-650 which was a beast, or so I thought. I can honestly say that one of the best routes to go for a subwoofer is an Internet Direct company, like SVS, Hsu, Elemental Designs, Epik, even just going a do-it-yourself route. Almost all of those, even in the lower end models will sound and feel better than your current Polk sub. Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx | ||||
| | #6 | ||||
| Re: Credit on my account - which option should I get next? I agree, given your situation the receiver will most likely yield the most improvement. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #7 | ||||
| Re: Credit on my account - which option should I get next? OK, so I've narrowed it down between the Marantz NR1501 Slim Line Receiver or the Harman Kardon AVR 1600 ... I currently have the AVR154, but the Marantz was recommended to me. Anyone have any insight on that particular model? HT Gear: Mitsubishi 60" DLP Marantz NR1501 Polk RM6750 Polk CS1 Polk Monitor 50's 2x Acoustic Research Wireless phones Toshiba HD-A20 Xbox 360 Pro Sony Uni-Remote | ||||
| | #8 | ||||
| Re: Credit on my account - which option should I get next? I can say that I am more fond of Marantz' in general. I think they are a higher class than the HK receivers. I've not heard much of that particular model, but I've heard other Marantz and been pretty impressed by them. Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx | ||||
| | #9 | ||||
| Re: Credit on my account - which option should I get next? I guess the one drawback of this particular Marantz is that it's not a dual zone - which I really liked about the 1600 and the avr254...but man, I'm loving all the positive feedback on the Marantz. HT Gear: Mitsubishi 60" DLP Marantz NR1501 Polk RM6750 Polk CS1 Polk Monitor 50's 2x Acoustic Research Wireless phones Toshiba HD-A20 Xbox 360 Pro Sony Uni-Remote | ||||
