Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater System Recommendations
SVS Cylinder Subs
Discuss SVS Cylinder Subs in the Home Theater | Audio and Video forum; SVS Cylinder Subs I was considering the SVS PB-12 for our HT room. It is a great Sub from what I was able ...
Views: 223 - Replies: 4
Old 10-18-09, 07:05 PM   #1
Alias: Mark
User: #35235
Since: Mar 2009
  markprovo is offline
SVS Cylinder Subs
I was considering the SVS PB-12 for our HT room. It is a great Sub from what I was able to research. However its size is a little too big for our room. I was looking for alternatives and came across the Cylinder Sub from SVS, the PC-13 Ultra and PC-12 Plus. They would fit perfectly for our HT room
My question to anyone is, Would I still be happy with the performance from these Subs even going with Cylinder style? Have anyone heard or tested the PC-13 Ultra and PC-12 Plus before? What can you tell me?
I'm thinking on getting one PC-13 Ultra now and probably another in the near future. This Sub will be part of my Monitor Audio Gold Series system. Would it go together well with my system?
Thanks in advance guys!
Old 10-18-09, 07:44 PM   #2
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
Re: SVS Cylinder Subs
SVS can tell you for sure, but cylinder performance should be almost identical to their boxed brethren and cost less to boot.
Old 10-18-09, 09:33 PM   #3
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
There is a slight drop in performance in the cylinder subs simply due to the Box having a much more ridged design but for the most part audibly they are the same. The PC13 ultra is a much better sub than the PC12 Plus due to the better driver design.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 10-18-09, 11:17 PM   #4
Alias: Tim
OvalNut's Avatar
Loc: North of Atlanta, GA
User: #1625
  OvalNut is offline
The reason for the slight performance difference between the PB13 and the PC13 is that the PB13 has a slightly larger internal volume. Box vs cylinder rigidity does not factor in. In actuality, the cylinder design is more naturally rigid and inflexible than a box, and thus an arguably better design in that respect.
Tim
He drove a black and white pirate ship at 190 mph.
- Dale in the #3 will never be forgotten. Thanks for the memories.
Old 10-18-09, 11:40 PM   #5
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
Looky what I found: http://www.svsound.com/questions-faqs.cfm#cylinderorbox
« Home Theater Shack > Home Theater | Audio and Video > Home Theater System Recommendations »
cylinder, subs
