| Home Theater System Recommendations Buying a sound surround sound system.Discuss Buying a sound surround sound system. in the Home Theater | Audio and Video forum; Buying a sound surround sound system. TheBuzzer wrote:
How many joules should I be suppressing for a home theather?
I would not go less than 2200
Views: 452 - Replies: 47
| | #26 | |||||
| Re: Buying a sound surround sound system. I would not go less than 2200 Quote:
If you can I do highly recommend running at least one dedicated circuit to the spot where your going to plug all this into. (just gives you a bit more peace of mind) Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | |||||
| | #27 | ||||
| Re: Buying a sound surround sound system. I have no idea how the circuity of the house is. I guess I can get a trip light. is this one good? newegg.com/Product/Product.aspx?Item=N82E16812120302 costco and newegg sell this one. | ||||
| | #28 | |||||
| Re: Buying a sound surround sound system. Quote:
Excellent choice on the Receiver, you are going to love it. Have you tried calling SVS Customer Service about your order? While I have never ordered from them, I have only heard great things about their CS. Surge protector is truly a proactive step. Especially if living somewhere with lots of lightning or brownouts. I personally like pre terminated Speaker Cables. Costs a little more, but you never have to worry about the connectors coming loose. I use Kimber Kables with WBT terminations for my Speaker Cables. Their locking bananas, while expensive, are an amazing connection making it impossible for accidental shorts. Cheers, JJ | |||||
| | #29 | |||||
| | #30 | |||||
| Re: Buying a sound surround sound system. Quote: newegg.com/Product/Product.aspx?Item=N82E16842111040 this one seems to have noise filter a bit expensive but seems to be the best for the value. | |||||
| | #31 | ||||
| Re: Buying a sound surround sound system. Yes, that a good one and has the cable and phone protection as well. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #33 | ||||
| Re: Buying a sound surround sound system. Its equivalent to the one sold by Monster that they charge you $200 or more for. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #34 | ||||
| Re: Buying a sound surround sound system. i personally use the APC 750 VA Its $100 bucks http://linkee.com/UcjWuD The nice thing about this unit is when the power goes off, your stuff stays on! 42" Insignia 1080P LCD, LG BD370 Bluray Player, Onkyo TX-SR507 Receiver (5.1), Energy Take Classic 5 pack Home Theater System, Sony SA-WM500 12" Subwoofer | ||||
| | #35 | |||||
| | #36 | ||||
| Re: Buying a sound surround sound system. I actually think its better to use a UPS plugged into a GFCI than a surge surpressor. I think the audio/video industry created a ton of hype with using surge surpressors. Personally if I get a spike in power I would rather have my power turn off and my system run on battery. 42" Insignia 1080P LCD, LG BD370 Bluray Player, Onkyo TX-SR507 Receiver (5.1), Energy Take Classic 5 pack Home Theater System, Sony SA-WM500 12" Subwoofer | ||||
| | #37 | ||||
| Re: Buying a sound surround sound system. A GFCI only protects the user it will not stop a spike of power coming in form the outside. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #38 | ||||
| Re: Buying a sound surround sound system. The linked APC does offer 365j of surge protection:http://www.apc.com/products/resource...50G&tab=models Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #39 | ||||
| Re: Buying a sound surround sound system. A class A GFCI will trip if it sences only 5ma of current change from whats coming in than what is going out... Yes they are made to protect humans but they will trip from a surge of electricity. I do see your point though.. I guess if you want the ultimate protection, I would plug your surge surpressor into a GFCI, Plug your UPS into your surge surpressor, and plug all your equipment into your ups. If you want the super duper ultimate protection.... just unplug your stuff during a lightning storm... a bolt of lightning can generate 10 billion joules of power 42" Insignia 1080P LCD, LG BD370 Bluray Player, Onkyo TX-SR507 Receiver (5.1), Energy Take Classic 5 pack Home Theater System, Sony SA-WM500 12" Subwoofer | ||||
| | #41 | ||||
| Re: Buying a sound surround sound system. Hello, Most quality receivers are indeed this big. Large power supplies and heat sinks take up a great deal of real estate. Most of the receivers you see at Best Buy are much smaller, weigh half as much and though are rated at similar power ratings, actually output often less than 1/2 the power. In addition these lower caliber receivers are more prone to thermal shutdown due to lack of heat sink size, lack of capacitance, etc, when driven to higher levels. While larger than perhaps what you are used to, you really have an excellent centerpiece to a high quality system that will provide you years of listening pleasure. Cheers, JJ | ||||
| | #42 | ||||
| Re: Buying a sound surround sound system. He He, yup, its a monster alright! You going to be pleasantly surprised how good it sounds. As Jack said the power supply is really the heart of the receiver and if its large your going to get allot more bang for your buck and far less distortion than other receivers in its price range. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #44 | ||||
| Re: Buying a sound surround sound system. Hello, Buying a stand would probably be a good call. Just make sure to allow a couple inches above the receiver as Onkyo's run warm. It is completely normal and they even make mention of it running hot on the top of the unit. Again, you really have gotten yourself an awesome receiver that will bring you years of joy. Cheers, JJ | ||||
| | #45 | ||||
| Re: Buying a sound surround sound system. i already have a tv stand but the cab size for it are not that big. based on the reciever size either i made the 3 section closer together to give more room for the bottom but than i would run into the problem of the center speaker too. where the other devices wont even be on the stand anymore | ||||
| | #46 | ||||
| Re: Buying a sound surround sound system. Personally I would not even put the Onkyo "in" a stand I would place it on top of a shelf with nothing over the top of it so it can breath properly. Nothing worse than heat to shorten the lifespan of a receiver or amp. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #48 | ||||
| Re: Buying a sound surround sound system. Hello, For what it's worth, for about a year I used a TX-SR875 strictly as a prepro (amplifiers not used) placed in a BDI Deploy Max rack that was so tight that I had to remove the feet to fit the thing in the available space. While I grant you the amplifiers were not used, they were still active as Onkyo does not allow you to turn off the amplifiers as some Denon's used to allow you to. I never had so much as a hiccup when placed in such a tight configuration. Intellectually, I knew it was wrong to have so little clearance so I dragged out an old Bell O'ggetti TV stand and placed it on top where the television would reside. The Bell O' rack is to the side of my other gear. If at all possible, placing on top of whatever stand you have is absolutely the way to go. All the same, even with my Onkyo placed in an open air configuration, it still runs hot. Especially in the back right where the HDMI board and Reon chip reside. Bottom line is these Onkyo's run hot. But, they next to never shut off due to heat buildup. This is something I have followed on many forums and has been exceptionally consistent in this regard. Cheers, JJ | ||||
