I'm trying to connect my wii, using component cables, to my Onkyo HT-S5300 receiver. I have the component video cables connected as in2 cbl/sat, and get the images on screen, but cannot for the life of me figure out where to connect the two audio cables so that I can also have sound.
If you have the component cables connected in the input labeled "CBL/SAT" then the audio should go in the audio input labeled "CBL/SAT" in the bank of Yellow, Red, and White connectors to the right. Yellow is composite video, don't use that one. Plug your Right Audio into Red and your Left Audio into White.
I am new to the forums and hope I have not committed a foul by bumping this thread.
Sound system n00b here. I have successfully hooked up my ps3, xbox 360, uverse stb, and dvd player all through hdmi on the onkyo ht-s5300 , so everything seems to be functioning well. My problem is the wii.
I hooked up the wii as described above, but I can not find any source buttons that show me the wii on my tv set. I am assuming I need component back to the TV.
Do I need an extra set of component cables that go from the component out of the receiver back to the tv?
I am having trouble finding a clear answer about this and assume the wii will not go through the current hdmi cable.
Should the setup be:
wii --> Component in cbl/sat + 2 audio cables plugged into receiver as described above
receiver --> second set of component cables out back to tv
Then what source/button do I use to view the component source after that?
No, Sorry. Per page 20 of the manual:
When choosing a connection format, bear in mind that the AV receiver doesn’t convert between formats, so only outputs of the same format as the input will output the signal.
So, you will need a component cable from the AVR to the TV.
I just ordered a new male to male component cable, so I should be able to get it going when it arrives.
Related Threads
742.3K posts
170.9K members
Since 2006
