| Home Theater System Recommendations Separates for ~$1,100Discuss Separates for ~$1,100 in the Home Theater | Audio and Video forum; Separates for ~$1,100 Emotiva Ultra-Lite LMC-1 + LPA-1 Combo
User reviews on "another forum"
For the cost of a "good" receiver, you can ... |
| | #1 (Link) | |||
| | Separates for ~$1,100 Emotiva Ultra-Lite LMC-1 + LPA-1 Combo User reviews on "another forum" For the cost of a "good" receiver, you can get a pre-amp and amp.. of course, until I hear it, I'll reserve judgement. Anyway, thought I'd share. JCD | |||
| | #2 (Link) | |||
| | Re: Separates for ~$1,100 Their Rockets have been extremely popular and well received for the most part considering their pricing. This setup looks pretty impressive for the price. I think that's about the least expensive processor I've seen... 500 bucks (Ultra-Lite LMC-1 Processor) and it even has 2 X 25 watts for zone 2. I wonder how it might compare to something like the Denon 3806 as a processor only. I figure the bulk of the cost for the 3806 is amplifier. Take that away and you are probably on an equal comparison field with processor only. I had been tinkering with the possibilities of the Outlaw... this LMC-1 might even be an option. I wonder has anyone here used it yet. | |||
| | #4 (Link) | |||
| Re: Separates for ~$1,100 I have both and am quite enamored with them! For reference, they replaced a Yammy RX-V2095. I must say that I'm hearing things I never heard before in a lot of my usual reference/show-off materials. The Pod Race, for instance, has a lot more incidental dialog and sound effects I never knew where there!! | |||
| | #5 (Link) | |||
| Re: Separates for ~$1,100 It really makes me wonder if pres are that much better than receivers. I hear it go both ways. Some people claim they went from a receiver to a Pre and the world opened up. Others have gone back to a singel reciever and claim no loss in clarity or sound. I would really like to see some blind, side-by-side comparisons with a few different models. Sure, using seperates has the wow factor and you think you are getting the best money can buy, but does that $500 receiver do just as well. Hmm. I personally just went through this dilemma. Building a HT. Finally decided on a less-expensive Pre. About the same price mid-range receiver and had all the features I really wanted. Some day I will compare it to my Denon and write a review. Roly | |||
| | #6 (Link) | |||
| Re: Separates for ~$1,100 Objective measurements on several receivers and pre-processors at Audioholics, Secrets, and Stereophile makes it clear to me that receivers or pre-processors are not necessarily better or worse than the other as a category. From my own experiences: Sony STR-DE597 is about as budget as you can get, but maybe one of the better budget units. Yamaha RX-V1400 is decent. Yamaha RX-V1400 + Outlaw Audio 7100 is the same as with the RX-V1400. Emotiva DMC-1 + Emotiva MPS-1 is significantly better than RX-V1400. | |||
| | #7 (Link) | |||
| Re: Separates for ~$1,100 Josuah, I am sure you are right. Have you seen any comparisons with cheaper processors vs. really expensive processors or cheaper receivers vs. very high end receivers? I am talking about objective tests or blind tests to see if their is actually an audible difference. | |||
