First HT setup, Yambeka? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater System Recommendations
Discuss First HT setup, Yambeka? in the Home Theater | Audio and Video forum; First HT setup, Yambeka? I am looking to get my first HT set up pretty soon. I am planning to buy a 50'' Samsung ...
Old 02-23-08, 12:40 PM   #1 (Link)
New Member
Alias: Max
Loc: Raleigh, NC
User: #17254
Since: Feb 2008
REDandBLACKpack is offline
I am looking to get my first HT set up pretty soon. I am planning to buy a 50'' Samsung HP-T5054 plasma television soon and I will want a nice sounding system for it. I am new to all of this so please bare with me. I have been looking around the forum and the Yambeka speakers seem to receive good reviews and are priced well. I would like to keep my whole set up, receiver, sub, speakers, wire, etc under $1000. I am unsure if I would go with the 7.1 or the 5.1. In the room I am in now the 5.1 would probably work better but next fall I will be in a bigger room I will have more space. I will be using my set up for daily tv use, playstation 3 , and blu ray movies, and maybe music listening if possible. Are the yambekas my best deal? I would like bass with my music and movies as well so what sub would you recommend? which receiver?
Thanks!
Old 02-23-08, 01:44 PM   #2 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
Re: first HT setup, yambeka?
Note: I wrote this post thinking you said "Yamaha" and not "Yambeka". I have no knowledge of that brand (although I have just read the thread) so I can't really comment on the sound. Given that, I'm letting this one through anyway as I think the points are still pretty valid.
I know this sounds bad, but a thousand bucks for a receiver, speakers and wire won't get you much.
If you really had a hard $1,000 limit, this is what I'd do:
Receiver
Onkyo SR605 -- I've seen it for as low as $385. It has a couple of HDMI inputs and supports the latest audio tech. It's as cheap as you can go and still get the latest technology with a good HDMI support
Speaker Wire
Go to your local Fry's, Home Depot, etc for your speaker wire. Buy a good sized spool of 14guage speaker wire of the generic variety. My opinion is that speaker wire is speaker wire and all you get from going with someone like Monster Cable is a name.
Interconnects
Two places to get them from IMO are monoprice.com and bluejeanscable.com. Both offer quality products and very reasonable prices. You could probably get your speaker wire there as well for the same price as Fry's or Home Depot. I think the cheaper stuff is at monoprice, but the stuff at bluejeanscable is probably of a higher quality. For the interconnects and the connection to the TV, HDMI is the way to go.
I'd guess that our total price tag is now somewhere in the $450+. That'd leave $550 for your speakers.
To get a sub of any quality, I think is gonna run at least $429 which is the entry level sub from SVS. Pretty much anything cheaper than this is going have bloated bass, high distortion, etc.
After that, we've only got $120 for the regular speakers. Probably the best quality entry level speaker out there is the SBS-01 from SVS. Those are $225/pair ($599 for a set of five). If you really have a budget, then maybe get just 2 and you've only gone over budget by $100. As funds permit, you can add to the system to fill out the remaining 3 or 5 speakers you want/need.
You have probably noticed that I didn't mention the Yamaha speakers. I know this is going to come off as snobbish, but there just aren't any speakers in the HTIB category that I think are any good. Any of them can "do the job", but if you're going to make that kind of investment, I'd want to get something that has some substance and quality. The suggestions I made above I think are the entry level for quality sound reproduction.
the other thing to note is that speaker preferences are not the same for everyone -- someone may love speaker A, but hate speaker B whereas someone else may go the opposite way. Neither is right or wrong, it's just what they like. That's why I suggest going out and auditioning speakers. The choices from SVS can be tried in home for 30 days. If you don't like them, you can send them back. You have to pay shipping, but I think you'd like them and not want to return them.
Another avenue to go is to look at used equipment. You can usually find some pretty good deals on ebay or audiogon.com or videogon.com. Obviously care must taken to make sure you don't buy something damaged.
Anyway, that's my opinion. Good luck and let us know how you do.
Oh, one more thing, you might want to take a look at this thread. It may help.
JCD
Old 02-23-08, 11:16 PM   #3 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is offline
I wouldn't spend the money on wireless rear speakers, especially for a small room. They won't sound great, and running wire should be a simple matter.
So, if I'm understanding right, you want to spend $1000, and get an AVR, and 5.1 speakers.
I'd grab an Onkyo 605 off Onkyo refurb or shop around, should be under $400. For a dorm,you won't be able to cranks the bass, so grab a Dayton sub for $150 from Parts Express. That leaves a little less than $100 a speaker. For that money, check out:
JBL/Infinity refurbs from the Official HK ebay store
av123 x-series
Look for used deals on Ebay, Audiogon, Craigslist
Save some money by getting...
Insignia 6.5" from Best Buy (used to be able to get these for <$50/pair)
Consider, spending all $450 on just 3 speakers, not 5. You can always add surround later, and 99% of the info comes from the front 3. You can buy better speakers now, and add rears when you have the $$.
Old 02-23-08, 11:33 PM   #4 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: First HT setup, Yambeka?
I moved this to Home Theater Systems since you are asking about more than just speakers.
The Yambeka systems have been getting very good subjective reviews. It seems for the money they are worthy.
Here's another option I'll throw at you... if you are interested in the Yambeka speakers, get the 5.0 system for now at $300. Snag the Dayton sub that Marshall recommends for $150. Now you have $550 remaining for an AVR. This would get you by for now in your smallish room. Look to upgrade when you move.
Sonnie
Old 02-24-08, 03:23 PM   #5 (Link)
New Member
Alias: Max
Loc: Raleigh, NC
User: #17254
Since: Feb 2008
so is buying all the parts seperate going to land me a better set up than buying a HTIB
Old 02-24-08, 05:36 PM   #6 (Link)
Alias: Jay
Loc: Western Wisconsin
jackfish's Avatar
User: #5100
Since: Dec 2006
jackfish is offline
REDandBLACKpack wrote: View Post
Oh yeah!
Old 02-24-08, 07:08 PM   #7 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
eugovector wrote: View Post
...grab a Dayton sub for $150 from Parts Express. That leaves a little less than $100 a speaker. For that money, check out ...
You can get one pair of JBL Arena $130 + one pair of JBL Monitor or Balcony $101 and JBL Voice (center) $101 ... that's five speakers for $332 plus $150 for the sub ... total $482.00
Old 02-25-08, 05:38 PM   #8 (Link)
New Member
Alias: Max
Loc: Raleigh, NC
User: #17254
Since: Feb 2008
salvasol wrote: View Post
What would be a good receiver to go with that? I would love to have one with ipod hookup.
Old 02-27-08, 12:01 PM   #9 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Any receiver will be okay ... usually you need at least 100WPC but more is better
I don't know what is your budget, but you can start looking here at the Shack electronics store http://www.hometheatershack.com/electronics-retailer/
Old 02-27-08, 01:08 PM   #10 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
This is totally dependant on the speakers you use and room size. Even 75watts per ch is sufficient if you have the right combination. but of course the more Watts the better headroom you will have.
Onkyo seems to be the Receiver of choice right now. As salvasol said it depends on your budget as to where you go from here.
Home theater:
Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD XA2 HD DVD & Samsung BDP1400 BluRay players, Sanyo Z2 projector
Two Channel system:
Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20, Nintendo Wii
« Home Theater Shack > Home Theater | Audio and Video > Home Theater System Recommendations »
Similar Threads
My Ht Setup tomscave Home Theater Gallery 6 07-21-08 07:13 PM
Yambeka Audio 7.0 Speaker System Review tweeksound Home Audio Speakers 15 07-20-08 08:13 PM
My Setup weeZ Home Theater Gallery 5 03-29-07 10:32 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195
