home theater budget allocation - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 21 Old 09-03-13, 03:32 PM
Re: home theater budget allocation
No problem, there may be forum members in your area that can help direct you to retailers other than Best Buy.
When funds are limited (and they always are) priorities have to be set and the budget is blown in the blink of an eye.
At the $1k price point it's hard to build an audio system to do justice to a projector setup.
Good luck and once you start auditioning some speakers come back to this thread and talk about what you like and dislike.
chashint is offline
post #12 of 21 Old 09-07-13, 10:59 PM
Take a look at my theater as I had a similar budget as yours.
I would look at Pioneers budget speakers and at least a Bic F12 or Klipsch RW12 to get you started.
neverfinished94 is offline
post #13 of 21 Old 09-08-13, 04:45 AM
JQueen's Avatar
One way to save money with a limited budget is monoprice for all Speaker wire and cords
JQueen is offline
post #14 of 21 Old 10-03-13, 11:45 AM Thread Starter
speedy John john's Avatar
I am back and have done some limited research. Have taken your advice on audio portion of budget. Listened to some speakers. So looking now at a 5.1 system. Budget as follows. 150.00 for center channel 200.00 per left and right tower, and 250.00 per pair of rear and side surrounds. So question is how much speaker wattage should I be considering for a small theater with acoustic panels. Room is 14 wide x 22 long. With 8 ft ceilings.
speedy John john is offline
post #15 of 21 Old 10-03-13, 07:41 PM
Greenster's Avatar
Your room is almost the exact same size as mine which is big enough to run 3 rows if you want. I am running a 115" screen which seems perfect to me from the middle row 12' away.
I think people on here have given you great advice. Start in your budget right now and upgrade things as you want or need to. You will not be able to build a basic room within your current budget, But you will be able to get one up and running to start with. Some ideas I have are:
Start with what you have now in speakers and AV.
If you dont have anything now then spend $100 and pick up some used speakers to just get you by. I always come across Polks here for dirt cheap.
Then save your $$$ for good or great speakers as your tastes change.. Arx's are a steal for their price. They just won the $1000 shoot out on here.
Go with a used projector to get you by as well. $300 will usually cover it. Thats what I am doing right now. (Panasonic PT-AX100U. It has hdmi and I can manually adjust it to both format modes)
You will want to go with something like the Panasonic 7000 or 8000 down the road. It changes from 16:9 and and 2.35:1. But these will set you back $2000+
Paint your front wall to save you some $$$ and get you up and running. Then go with a true screen when the funds allow.
Pre run all of your cables of make it so you can run cables later without having to rip out sheetrock.
Install inwall surround speakers. 7.1.. Or just run the cables and wires to the locations at first. You may want to run inwall speakers due to the size of your room.
Make your own acoustic panels. This made the biggest improvement I made on my room. You will want to do this. Just search this forum on it. I spent less than $200 for mine including acoustic fabric.
Last advice. Slowly learn from or get addicted to this forum. There is a ton of really smart and nice people on here willing to help.
A link to mine. You will probably pass me within a month or so. I am quite slow in my build.
Greenster is offline
post #16 of 21 Old 10-03-13, 11:53 PM Thread Starter
Great advice. Thanks, what I getting at is not that I don't have the cash but what makes sense. I want to finish this in the next month and do not want to over spend. Instead of becoming an expert on HT I would rather invite you all over for a cold draft at the custom bar while watching the game and enjoying a good cigar, not worrying about the smoke because I already installed a custom HVAC system to eliminate it. So tell me if this was your house what speakers would you buy. Thanks again, really enjoying this but have to hit the road again hope to retire soon.
post #17 of 21 Old 10-04-13, 07:18 PM
Put TV15 code in the shopping cart for 15% discount.
For your budget I think this will be hard to beat.
This level of AVR or lower is what I would target keeping in mind the amount you are willing to spend for speakers.
chashint is offline
post #18 of 21 Old 10-06-13, 10:27 PM Thread Starter
Sweet, thanks for the links. Looks great. So you don't think that would be to much for my room size? I plan on installing 2 acoustic panels on front wall, 3 on each side wall and 2 bass traps on the back wall. You guys are great. I do want to do this right the first time if possible. Well I am headed to south Georgia another 800 miles. Thanks again. John
post #19 of 21 Old 10-08-13, 07:50 PM
Horrorfan33's Avatar
I am a big fan of Polk Audio, and their value/sound ratio is unbeatable in my humble opinion..Here is what I would go with from newegg.com
Front Speakers--Polk Audio Tsi400 ($200 each)
Center Channel--Polk Audio CS2 series II ($150)
Rear Speakers--Polk Audio Monitor 45B ($250 pair)
Subwoofer--Polk Audio PSW505 ($230)
I think you will be pleasantly surprised of the sound of this set up!!..Newegg also gives you free shipping!!
Good luck and keep us updated!!
Horrorfan33 is offline
post #20 of 21 Old 10-08-13, 08:14 PM
HTS Senior Moderator
ellisr63's Avatar
Another speaker to check out would be Boston Acoustics... They were the first speakers used in the THX theaters. They are inexpensive and sound great.
Benq W1070 projector and make your own screen... Leaving the remaining budget for a receiver and speakers.
My Home Theater
Yamaha CX-A5100, (3) JBL 2360A/EV DHA-1s, (3) 1/4 Pie bass bins, (2 pr) JBL 8340As, (2 pr) JBL 8320s, PS3, XBox One, (2) Intel NUCs, Redmere HDMI cables, Monster Signature HTPS7000, (2) Furman Power Conditioners, (2) DTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diag) scope screen, Darbee Darcet, Panamorph UH-480 lens, (2) Crest Audio 2208, Yamaha XM-4080 & P7000s, (2) MiniDSP DDRC-88M, Pioneer BDP-80DF
My Go Big or Go Home Theater Construction Thread
ellisr63 is offline
allocation , budget , home , theater
