Advice - Recommendations - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater System Recommendations
Discuss Advice - Recommendations in the Home Theater | Audio and Video forum; Advice - Recommendations I am new to the Home Theater Shack and looking for advice or comments. I am looking to purshcase my ...
Old 03-23-08, 01:53 PM   #1 (Link)
New Member
Alias: cbose
Loc: CHICAGO
User: #18631
Since: Mar 2008
chuck bosley is offline
I am new to the Home Theater Shack and looking for advice or comments. I am looking to purshcase my first system and have my eyes on the following - Mitsibushi wd65833 tv - Yamaha RX V1800 receiver and Focal SIBSYSB home theater speakers. I'm wondering if any memebers have these components and could offer any feedback. I have also found a Yamaha RX V2700 receiver for around $600.00 less that the V1800. Anyone have any comments on this. Just looking for some advice! Thanks,
Chuck
Old 03-23-08, 03:06 PM   #2 (Link)
Alias: Mfishmike
Loc: League City, Texas
Mike Cason's Avatar
User: #7558
Since: Mar 2007
Mike Cason is offline
Re: Advice - Recommendations
chuck bosley wrote: View Post
Chuck
I see you don't have any replies yet.....I've got the Mitsubishi WS65"***" Diamond series rear projection and have had it for 3 years with no problems. I've been told by some high end audio stores that my model should give me a good 8 to 15 years of good use. We use it daily and have had no problems. I removed the plastic anti-glare shield because my subs ratteled it too much and I actually have a better picture from both the front viewing area and also at an angle from my sit up bar where I eat.
I have no kids, cats, or hand grenades to hurt the underlying screeen. Dust it very lightly with a slightly damp cloth when you think it needs cleaning and tell your buds to keep their fingers off the screen.
As far as the rest of the gear, including your tv, I would Google each item and type in for example:
"Yamaha Rx V1800 reviews" and you should find some interesting answers. I would do the same for each piece of equipment you are looking to purchase. Go to the mfgs websites and look up the items and if you don't find them, look for an archive file which can sometimes be found on the mfgs sites. You can sometimes get users manuals, specs, length of production, and other info there.
Look on Ebay too. Look for the archived sales and that will tell you what you should be paying as they now list sold comparisons.
Focal makes some of the finest drivers in the world, but they will probably have some entry level drivers they may put in their cabinets. Google them too. Find out which drivers they are using and go to Madisound or Parts Express, or maybe even Focal (overseas) and get some info there. Google's a great tool.
Good luck
Mike
Old 03-23-08, 05:58 PM   #3 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is online now
I can only give you my opinion on the Yamaha RXV-2700
I got it on 12/07 and I'm happy with the receiver ... 140WPC, HDMI, opt, etc. before the Yamaha I used a Sony STR-DE897 but the Yamaha is much better
The big difference between the 1800 and 2700 is the True HD ... you can compare both model here www.yamaha.com/yec ... I'm not sure how you plan to hook up your system (TV, Sat/Cable, VCR, DVD, etc.) this will make the difference to choose your receiver; if you're planning to get a Blue Ray player and connect all video signals through the receiver your best bet is the 1800 ... but if you will connect the video signals to TV and the audio to receiver (like me) you'll be fine with the 2700 ...
Good luck with your purchase
Old 03-24-08, 02:04 PM   #4 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Hello Chuck, Welcome aboard the Shack.
The Yamaha receivers are very good and you would not be disappointed. The 2700 is a great deal.
May I ask if you have looked at any other receivers? Denon or Onkyo as well make some great receivers. The Shack store has the Onkyo TX SR805 for just over $700 and free shipping. Its a fantastic receiver and bang for buck if you can streach your budget just a little bit you get allot more including THX Ultra certification.
For speakers I would look at the SVS SBS-01 speaker system. For the same price as the ones you mentioned above. They are getting great reviews and you get a great sub to go with them included.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears,
SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's
Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's, & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 03-30-08, 07:54 PM   #5 (Link)
Alias: lightclouds
User: #17273
Since: Feb 2008
lightclouds is offline
Well Onkyo TX SR805 is very good and so the Onkyo TX-SR705, and right now the price for the Onkyo TX-SR705 is quite nice, a recent deal on it, you can have a look at it.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater System Recommendations »
Similar Threads
Any other recommendations Atrocity Home Theater System Recommendations 6 01-29-08 12:35 PM
Opinions/recommendations! Chris Nitro Home Theater Projectors 16 01-06-08 05:39 AM
Book Recommendations Bob_99 Home Audio Acoustics 6 06-21-07 04:23 AM
Any recommendations on changes for my current room 1984911Porsche Home Theater Design and Construction 3 06-16-07 08:11 PM
Receiver Recommendations Darrel Hawthorne Home Theater Components 16 07-19-06 04:34 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
