Denon AVR 2801 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Denon AVR 2801
Discuss Denon AVR 2801 in the Home Theater | Audio and Video forum; Denon AVR 2801 I own Denon AVR 2801 reciever and will try to use for my HT i also have PS3 that will ...
Old 03-23-08, 10:39 PM   #1 (Link)
Alias: don5738
User: #15181
Since: Jan 2008
don5738 is offline
Denon AVR 2801
I own Denon AVR 2801 reciever and will try to use for my HT i also have PS3 that will play all DVD I have epson projector that has vga plug how will all this work out as far as connections? or is this reciever too old? I am trying to use it if possible it works great also I will be installing HD cable box is this possible I'm a little confused can anyone help?
Old 03-24-08, 12:43 AM   #2 (Link)
Loc: Lower Alabama
Re: Denon AVR 2801
I do not believe you will get all this to work too well, if you do it will be sub-par video performance at best.
The 2801 is very old and only offers s-video and composite video connections, no component and no HDMI.
You need to upgrade your receiver for optimal performance.
You can connect the optical out on the PS3 to the receiver and get sound for it. It depends on your cable box as to how you can connect that sound... if it has optical you can connect it to another optical input on the receiver.
For video... I am not sure what to tell you if the Epson only has VGA.
Old 03-24-08, 12:42 PM   #3 (Link)
Alias: don5738
User: #15181
Since: Jan 2008
don5738 is offline
Re: Denon AVR 2801
thanks for the help I talked to the guys at monoprice.com he said they make a cable from VGA to component so I guess I will be buying new reciever any suggestions?
Old 03-24-08, 03:46 PM   #4 (Link)
Alias: Zip
Loc: London, Ontario, Canada
MatrixDweller's Avatar
User: #10408
Since: Jul 2007
MatrixDweller is offline
Re: Denon AVR 2801
To reiterate...The 2801 doesn't have component outputs. It only has S-Video and composite. Don't confuse composite for component as they are two different animals altogether. The only way to go from s-video (or composite) to svga is via a converter Like this one. s-video and composite signals do not have all the information that svga needs so a special converter is needed. They don't make an "in cable" solution.
Most projectors have more than one input on them. What model of Epson projector do you have? Are you sure it doesn't have composite or s-video inputs?
...Sorry misread your broken engrish.
Not too many AVRs have svga out so you'll still need a special cable no matter what you buy. What is you budget for a new receiver?
Old 03-24-08, 05:16 PM   #5 (Link)
Alias: don5738
User: #15181
Since: Jan 2008
don5738 is offline
Re: Denon AVR 2801
EPSON 72c is projector and it does have s- video also I wanted to use component cable for video won't that give a better picture then s-video? I 'm thinking of spending for new reciever around 500.00 so I would like to get a reciever with HDMI inputs for ps3 in time I would like to purchase a better projector but this epson was given to me so I wanted to upgrade later on not now with the cost of building dedicated room I'm alittle low on cash!!!!
Old 03-24-08, 05:22 PM   #6 (Link)
Alias: superchad
Loc: ohio
User: #17760
Since: Mar 2008
superchad is offline
Re: Denon AVR 2801
Why not just run video straight from player and not go into reciever? This will give you the purest signal anyway so it should be ideal and adds 1 extra remote to operate so it is not at all that big of a hassle.
If the reciever has on screen display for set-up then simply run a Composite or S video for that and your done..............will this work for you? This way everything is working and you dont have to spend money right away so you can save for a better unit or whatever.
Old 03-24-08, 05:51 PM   #7 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Re: Denon AVR 2801
superchad wrote: View Post
I agree with this suggestion ... for the audio just connect an optical cable (you have 3 on your 2801) or a coaxial (one on 2801) for each source (DVD, Cable/Sat, etc.)
Save those $500 to build your new HT
Old 03-25-08, 01:00 AM   #8 (Link)
Alias: don5738
User: #15181
Since: Jan 2008
don5738 is offline
Re: Denon AVR 2801
well if that will work great now let me understand this I can run audio from lets say ps3 to reciever with optical and run video from ps3 to projector with s video? then run say cable box to reciever with optical also and video also with s video cable right?
Old 03-25-08, 09:20 AM   #9 (Link)
Alias: Zip
User: #10408
Since: Jul 2007
Re: Denon AVR 2801
I'd run component from the PS3 to the projector and optical from PS3 to your receiver. Component is superior to s-video and can give a noticeably cleaner image especially with high def signals.
In the $500 range the Onkyo TX-SR605 is a good deal. Onkyo will be releasing a couple models in the months to come that may be of interest also. The TX-SR506 and TX-SR576 will be very good entry level receivers and should meet or exceed your budgetary constraints. The TX-SR606 should be out before summer, so I would wait a while to purchase a "new" receiver since the price of the 605's will plummet at that time.
Old 03-25-08, 01:32 PM   #10 (Link)
Alias: superchad
Loc: ohio
User: #17760
Since: Mar 2008
Re: Denon AVR 2801
don5738 wrote: View Post
If you have Component inputs that is best but yes you have got the idea now!
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
Similar Threads
Denon AVR-3808ci - Any Thoughts? mickeypups Home Theater Components 12 04-01-08 03:04 AM
FS: Denon AVR-1905 Ayreonaut Classifieds - Audio Equipment 1 02-08-08 09:13 AM
FS: Denon AVR-2106 chas Classifieds - Audio Equipment 0 05-18-07 07:11 PM
Denon AVR-2807 Receiver Sonnie Home Theater Components 19 04-19-07 11:38 AM
FS: Denon AVR-3806 Receiver Sonnie Classifieds - Audio Equipment 1 09-15-06 07:17 AM
Mach 5 Audio
