| System Setup and Connection Hooking up PC to Onkyo Receiver?Discuss Hooking up PC to Onkyo Receiver? in the Home Theater | Audio and Video forum; Hooking up PC to Onkyo Receiver? I would like to hook-up the video and audio from my Dell computer to my Onkyo Receiver TX-SR605 receiver and ... |
| | #1 (Link) | |||
| Hooking up PC to Onkyo Receiver? I would like to hook-up the video and audio from my Dell computer to my Onkyo Receiver TX-SR605 receiver and thus a 7.1 surround sound system hooked up to a Samsung LN-T5781F 57" LCD Flat Screen. The purpose is to play video games, saved on my PC, I have onto the LCD Flat Screen with possible surround sound. Sound Card: Creative SB Live Video Card: Radeon X1300/X1550 Series Questions: 1- What is the best audio/video cable connection configuration to do the job. Attachment shows a picture of the back of my computer (sound card on top and video card on bottom)? 2- Do I have to change the sound card to transfer 7.1 surround sound to receiver? 3- Do the PC games have to be in surround sound? How do I know if they are? The Onkyo receiver has the following inputs: HDMI component video in S-Video in Optical Digital in Coaxial Digital in | |||
| | #2 (Link) | |||
| Re: Hooking up PC to Onkyo Receiver? I take it that is a Live 5.1 that came with the Dell? If so, simply connect a 3.5mm mono to RCA adapter to an analog coax cable (yanno, RCA connectors) and plug into the SB Live orange (S/PDIF) and the other end into your receivers Digital Coaxial input. This card is not capable of 7.1, but your receiver should be able to matrix it. If you want true 7.1, yes you will need a new sound card. PC games do not have to be in surround (though many are), thats what all the fancy sound processing features on a receiver are for I'm really not up on the 605, but most receivers will let you know if they are getting 5.1 with: a blue light (Sony), an icon per channel (Denon), etc. etc. From the looks of the Onkyo I'd bet it has an icon that lights up indicating DD5.1 or DTS or whatever format it's receiving.Mark | |||
| | #3 (Link) | ||||
| Re: Hooking up PC to Onkyo Receiver? Quote:
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | ||||
| | #4 (Link) | |||
| Re: Hooking up PC to Onkyo Receiver? Get three 3.5mm to RCA cables you have three outputs there. so you should be able to get 5.1 analog out. connect to the onkyo multichannel input, thats how I have mine. As far as video if you wanna play games but nothing to hard get yourself the 3850 (just over a bill) it has a dvi hdmi and ati also has hdmi audio (nothing more than 2 channel PCM/bitstream, but its nice to have all on one cable) If you want to get into serious gaming the new ati cards are almost out (everwhere says June) so wait for those. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Noise in system when hooking up HD PVR | tonyvdb | General Discussion | 10 | 01-28-08 03:55 PM |
| Hooking up a sony HDZ235 to a Mitsubishi HD1080 TV | longboarder | General Discussion | 9 | 12-31-07 04:30 PM |
| Questions re Onkyo TX-NR1000 Receiver | thenrie | Home Theater Components | 3 | 09-17-07 01:02 PM |
| Hooking up another set of speakers in another room. | John N | General Discussion | 21 | 08-29-07 03:01 PM |
| Onkyo TX-SR803 THX Select2 7.1 A/V Receiver | Sonnie | Home Theater, Audio and Video News | 0 | 06-09-06 01:42 AM |
