| System Setup and Connection Kenwood Home Theatre System Help Required !!!Discuss Kenwood Home Theatre System Help Required !!! in the Home Theater | Audio and Video forum; Kenwood Home Theatre System Help Required !!! Hi I would like to know if you guys can help me hook up my HTB-504 Home Theatre system which ... |
| | #1 (Link) | |||
| Hi I would like to know if you guys can help me hook up my HTB-504 Home Theatre system which has a receiver model # of VR-507. If you guys can help me out then i will provide more details of my issue/problem but if you guys can't help me out then can you kindly provide me with links to people who can help me out with this issue. Please respond ASAP. | |||
| | #6 (Link) | |||
| Thanks alot for the warm welcome guys i'm having a great feeling about these forums. Let me start off from beginning so you guys have a better understanding of what my problem is. A friend of mine bought this HTB-504 Home Theatre system which has a receiver model # of VR-507 and used it for a few months and then gave it to me. I have no experience with these things so i read a couple of manuals which came with the opened box and hooked up all of the six speakers with the receiver as it was showed in the manuals. Next i tried to hook up the system with my TV and got stuck in this step and need your help here. To get a general idea of what my system looks like please follow this link http://www.crutchfield.com/S-TJHUNmc...=113HTB504#Tab Now once you know the specifications and equipment, to give you guys a better idea here are some home based images of the above system I have a Samsung TXK2750 TV and this is how the back of my TV looks like Pretty simple i know, now is it possible to hook up my TV to my HTS (home theatre system) so that all the audio comes through HTS speakers instead of the TV's speakers ??? If it is possible then please tell me what wire goes where ? If possible can you please pin-point what goes where according to the images ??? I've tried all kinds of combos and nothing works and that's why i'm asking this newb question which i'm sure you guys won't have a problem answering. Thanks in advance Last edited by unstopabl3; 03-02-07 at 08:09 PM. | |||
| | #7 (Link) | |||
| Re: Kenwood Home Theatre System Help Required !!! Oooh,....thats gonna be tough, the TV is going to cause problems if those are the only connections on the back of the TV. No outputs? Do you have a Dish Network receiver or Cable Box? Or just over the air TV signals? Mark | |||
| | #8 (Link) | |||
| Re: Kenwood Home Theatre System Help Required !!! wow i had that same system as my first HT setup... to follow up on what mark was saying if no cable box or satellite reciever do you have a VCR or any other components in your set up? | |||
| | #9 (Link) | |||
| Re: Kenwood Home Theatre System Help Required !!! Yes i've got rogers cable and I have a digital box/receiver given by rogers called " Scientific Atlanta Explorer 1840" Here are some pictures of this box I also have a Zenith DVC2200C DVD player and here is a picture of that So can you please help me setup my system with this information. Will greatly greatly appreciate it ![]() | |||
| | #10 (Link) | |||
| | Re: Kenwood Home Theatre System Help Required !!! This diagram should help. For your system, just substitute connections to the yellow video jacks instead of the red/green/blue ones they show. The cable box will connect the same as the DVD player, only to a different input. Regards, Wayne | |||
| | #11 (Link) | ||||
| Re: Kenwood Home Theatre System Help Required !!! Quote:
| | #14 (Link) | |||
| Re: Kenwood Home Theatre System Help Required !!! I looked at the diagram and I bought 4 RCA plugs (gold plated) and the first one I put according to what you told me, from first side one yellow plugged into the receivers Video Monitor Out jack, one white plugged into the receivers white Monitor REC OUT (Audio) jack, one red plugged into the receivers red Monitor REC OUT (Audio) jack. The second side of this wire i hooked it up in the TV yellow/red/white jacks. Next I took a second RCA plugged the first side of this wire into the yellow/red/white jacks on my DVD player and plugged one yellow wire from the other side of this wire into the receiver's CD/DVD DVD VIDEO INPUT and plugged the red/white wires into the CD/DVD AUDIO Jacks. I inserted a dvd movie into my DVD player and I turned on my receiver and speakers and I hear sound coming from the TV sounds system instead of the home theatre system. What am i doing wrong ??? Do i have to do some configuration/setup through the receiver to hear sound from the theatre speakers ??? Thanks in advance | |||
| | #15 (Link) | |||
| Re: Kenwood Home Theatre System Help Required !!! ok. try this. run the video (yellow) from the monitor out on reciever to video in (yellow) on TV. from the digital boxes outs (red/white, Yellow) plug into Video 1 in (yellow) and Video 1 in (red white) now if you set your reciever to video 1 and your TV to input you should get sound/picture from cable box. for the DVD run Video/audio outs to the DVD/CD video/audio ins on your receiver. switch receiver to DVD/CD and keep TV on your video source and it should work. Remeber all outs on your peripherals will go to ins on your receiver. Also, if you want 5.1 I would invest in a coaxial or toshlink for you DVD player to run to the receiver. | |||
| | #16 (Link) | ||||||
Also, it looks like you didn’t follow any of the instructions we’ve given, or the diagram I linked. You only needed one set of yellow/red/white cables to connect the cable box to the receiver. The red/white is because the cable box doesn’t have a digital audio output – remember this? Quote:
And... Quote:
Hope this helps – this should get you up and running. Regards, Wayne | ||||||
| | #17 (Link) | ||||
Good Luck | ||||
| | #18 (Link) | |||
| Re: Kenwood Home Theatre System Help Required !!! Unbelievable how as to how welcoming you guys are to newbs The guy who gave the system to me actually got it hooked up professionally so asking him was out of the question. I'm not hooking this system up for myself but for my friend. I was very very busy past few days so i wasn't able to reply back but I got around to re-wising everything you guys told me and got the HTS to finally blow my neighbors ears The issue was not how i cabled the system it was actually receiver based settings which i had to play around with to get it going ![]() Everything works like a charm and my friends a happy fella. Thanks for the help guys ![]() | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| New Home theatre person | willij100 | Welcome | Member Introduction | 10 | 02-27-07 10:41 AM |
| Optical out not working with Home theatre system | pickychick | Remotes | Cables | Accessories | 1 | 02-18-07 04:56 PM |
