Setting Up Your Home Theater 101 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Discuss Setting Up Your Home Theater 101 in the Home Theater | Audio and Video forum; Setting Up Your Home Theater 101 Thought I'd compile a few sites that helped me out with the audio portion of my Home Theater. Hopefully they ...
Old 03-30-07, 05:22 PM   #1 (Link)
Alias: DrPainMD
Loc: NB, Canada
DrPainMD's Avatar
User: #6014
Since: Jan 2007
DrPainMD is offline
Thumbs up Setting Up Your Home Theater Audio 101
Thought I'd compile a few sites that helped me out with the audio portion of my Home Theater. Hopefully they will help some of you out there.
I've linked to a lot of sites here, so many thanks to them.
This is a work in progress.
I think I overdid the 101, after the second link. LOL
If you know of anymore .....
Please start your own thread if you have questions. You'll get a better response.
General
Home Theater Explained by Marc J. Rochkind
Dolby Home Theater Equipment
Home Theater Shacks' Glossary
Audioholics - Glossary of Electronics Terms
Home Theater Talks' Glossary of Home Theater Terms
The Dolby Guide to Home Theater Sound
Home Theater HiFi's - How a Hole-in-the-Box Works - A Big Dig into Bass Reflex
CePro's - Setting Up a Multi room A/V System
Aperion Audio's University
Receiver, Amplifier, DVD Player - General Setup
Audioholics - Receiver Setup and Connections
Audioholics - Basic Audio & Video Set-Up Guide
Audioholics - Heat Buildup and Your AV Components
Audioholics - DVD Player Setup
Audioholics - DVD Audio Setup Tip
Audioholics - Home Theater Set-up Basics
Home Theater HiFi's - Using the Auto Set-up and EQ Features in an SSP or Receiver
Home Theater HiFi's - DVD Player Benchmarks
Crown's - How Much Amplifier Power Do I Need?
Audio Formats & Technology
Dolby Technology Overview - TrueHD/Digital Plus/Surround EX/Pro Logic IIx etc...
DTS FAQ
DTS-HD
DTS-HD FAQ
DTS on Blu-ray & HD-DVD
THX Technologies
Audioholics - What is Dolby Digital Surround?
Audioholics - Dolby Digital vs. DTS: A Guide to the Strengths of the Formats
Audioholics - THX Select and THX Ultra2 Certification - General Questions
Home Theater HiFi's - THX-Certification: What It Means and How to Use It
Home Theater HiFi's - Pro Logic IIx: What it Is, How it Works, and a Comparison with Other Formats
Interconnects, Cables and Connections
Audioholics - Audio & Video Connections Guide
Audioholics - Connection Tips 101 - Cabling Your System
Audioholics - Home Theater Prewire Basics - Introduction
Audioholics - Signal and Connector Types
Audioholics - Whole House HT Wiring Basics, Part 1
Audioholics - Whole House HT Wiring Basics, Part 2
Audioholics - Whole House HT Wiring Basics, Part 3
Audioholics - Whole House HT Wiring Basics, Part 4
Audioholics - Understanding In-wall Speaker, Video and Audio Cable Ratings
Audioholics - The Truth About Interconnects and Cables
Audioholics - Connecting a Cable TV or Satellite System
Audioholics - HDMI 1.3 Q&A
Audioholics - Understanding HDMI Ver 1.3
Audioholics - HDMI Interface - A Beginner's Guide
Home Theater HiFi's - DVI and HDMI Connections and HDCP Explained
Audioholics - HDMI 1.3 and Cables Part 1: It's All in the Bitrate
Home Theater Mag's - Speaker Wire Installation & Wiring
Blue Jeans Cables - Cables FAQ
Ram Electronics - How to connect your Home Theater
Roger Russell: Speaker Wire - A History
Roger Russell: What Speaker Gauge Should I Use
Bi Amping - Bi Wiring
Audioholics - Bi Wiring: From Amplifier To Loudspeaker, Part 1
Audioholics - Bi Wiring: The Cable Conundrum, Part 2
Audioholics - The Difference Between Bi Amping vs. Bi Wiring
Ground Loops and Hum
Audioholics - Thinking in Isolation – A Primer on Ground Loops
Audioholics - Ground Loops - Eliminating System Hum and Buzz
HUM FAQ by Bill Lummus
Home Tech - RF Attenuators, Filters, & DC Blockers
Impact Acoustics - Isolation Transformers
Speaker Layout
Dolby Speaker and Room Setup
DTS 7.1 Channel Setup
THX 5.1 Speaker Layout
THX 7.1 Speaker Layout
Loudspeakers and Rooms for Multichannel Audio Reproduction, Part 1 by Floyd E. Toole from Harmon
Loudspeakers and Rooms for Multichannel Audio Reproduction, Part 2 by Floyd E. Toole from Harmon
Loudspeakers and Rooms for Multichannel Audio Reproduction, Part 3 by Floyd E. Toole from Harmon
Audioholics - Speaker Placement: Setup Tips for Upgraded Home Theater Systems
Audioholics - Loudspeaker Placement Guide
Audioholics - Home Theater Speaker Layout - An Essential Guide
Audioholics - Speaker Spikes and Cones – What’s the point?
Audioholics - Vertical vs Horizontal Center Speaker Designs
Bob Golds, Sanjay Durani - Dipole Surround Placement
Speaker Setup, Using SPL Meter
Techlore - How To Calibrate Your Surround System Using an SPL Meter
Audiophilia - Essential Accessories: The Radio Shack Sound Pressure Level Meter
Audioholics - Setting Speaker Levels & Distance in a Surround Sound System
Subwoofer Setup and Placement
Audioholics - Crawling for Bass - Subwoofer Placement
Audioholics - Subwoofer Placement Tips for Cabinetry Installations
Audioholics - An Easy Solution To Subwoofer Calibration
Audioholics - Bass Management Basics – Settings Made Simple
Audioholics - Subwoofer Placement Guidelines
Audioholics - Subwoofer Placement - The Place for Bass
Audioholics - Connecting a Subwoofer to a Receiver
Audioholics - Connecting a Subwoofer to a Receiver with No Subwoofer Output
Audioholics - Subwoofer Calibration Using Rives Audio Test CD 2
Audioholics - Setting the Subwoofer / LFE Crossover for Best Performance
Audioholics - Subwoofer Measurement Tactics: A Brief, Topical Overview & Method Comparison
Axiom - How to Find the Best Place for Your Subwoofer
Home Theater HiFi's - The Misunderstood 0.1 LFE Channel in 5.1 by Brian Florian
Sub Placement & Setup by Tom Nousaine, Chu Gai
AVIA: Subwoofer Calibration by Guy Kuo
Common Subwoofer Set-Up Errors by Edward J M
SVS - Ed Mullen's Subwoofer Setup Tips
SVS - How do I use a sound level meter to calibrate my Subwoofer
Subwoofer Setup Guide by Bossobass
What's the Big Deal About Crossovers?
LFE, Subwoofers and Interconnects Explained
Home Theater HiFi's - Bass Management Woes: Trouble on the Slopes
Sound Treatments and Acoustics
Audioholics - Introduction to Acoustics
Audioholics - DIY Absorbers for the Less-than-Handy Man
Audioholics - Acoustical Measurements - What are They?
Audioholics - A Guide to Sound Isolation and Noise Control
Audioholics - Room Acoustics: Isolation & Noise Control
Audioholics - Reducing HVAC Noise in Theater Rooms
Audioholics - Early Reflections in Home Theaters: A Different Perspective
Audioholics - Building Great Bass Response In Your Home Theater
Audioholics - Audyssey Labs' MultEQ
Audioholics - The Perfect Room?
Audioholics - Room Acoustics: Acoustic Treatments
Audioholics - Acoustics 101 Course by John Dahl of THX
Audioholics - Acoustics Facts and Fiction by Ethan Winer
Audioholics - Bass Traps - Not Just for Fisherman! by Ethan Winer
AVS - Acoustical Treatments Master Thread
Home Theater HiFi's - Acoustical Room Treatment: A Survey of Methods and Materials
Loudspeakers and Rooms - Working Together by Floyd E. Toole from Harmon
Maximizing Loudspeaker Performance In Rooms by Floyd E. Toole from Harmon
Audio – Science in the Service of Art by Floyd E. Toole from Harmon
Acoustical Concepts of Contemporary Home Theaters by Ryan O. Allen
Jon Risch's DIY Acoustic Treatments
Cutting Rigid Fiberglass for Bass Traps
Bob Gold's Absorption Coefficients
Acoustic Treatment and Design for Recording Studios and Listening Rooms by Ethan Winer
Real Traps - Acoustic Treatment Overview
ATS Acoustics - Sound Absorption and Acoustical Panel FAQ's
GIK Acoustics - Acoustics Primer - Some Basics On Acoustics
Ready Acoustics - Acoustical Primer
Sensible Sound Solutions
Sonopan Acoustics
Quiet Rock - THX Certified Drywall
Green Glue
Auralex SubDude
Owens Corning Rigid Fiberglas 700 Series Insulation
Equipment
Behringer Feedback Destroyer Pro DSP1124P
Home Theater Shack: BFD Guide
Home Theatre Shack: BFD Links
Audioholics - Active Room Correction: A Primer to Audyssey MultEQ Pro
Sound Pressure Level (SPL) Meters
Radio Shack Digital-Display Sound-Level Meter
Radio Shack Analog Display Sound Level Meter
Radio Shack SPL Meter Correction Tables
SVS's Radio Shack SPL Meter Compensation Chart
Galaxy Audio SPL Meter
Software
Ovation Multimedia - Avia: Guide To Home Theater DVD
Video Essentials: Get The Most Out Of Your Home Entertainment System DVD
AVS - jeffreylebowski's Free Software for First Reflection Points
Room EQ Wizard Help Thread
Home Theater Shack: REW Forum
Home Theater Shack: Room EQ Wizard
Home Theater Shack: BFD Links
SPL Calculator by C.M.Collins
Harman Kardon - Waves & Modes-A Room Resonances Locater (XLS spreadsheet)
TrueRTA Audio Spectrum Analyzer
TrueRTA For Dummies
Audio Spectrum Analyzer - Spectrum Lab (Waterfall Chart)
Test Tones
Realm Of Excursion (Download Section)
RealTraps - Test Tone CD
Bink Audio Test CD
Stay in Tune with PentaTone
Thanks
©DrPainMD
Old 05-02-07, 05:48 PM   #3 (Link)
Alias: DrPainMD
Loc: NB, Canada
DrPainMD's Avatar
User: #6014
Since: Jan 2007
DrPainMD is offline
Re: Setting Up Your Home Theatre 101
Added:
Old 05-07-07, 05:41 AM   #4 (Link)
Alias: DrPainMD
Loc: NB, Canada
DrPainMD's Avatar
User: #6014
Since: Jan 2007
DrPainMD is offline
May 7, 2007
Added:
Old 07-10-07, 07:04 AM   #5 (Link)
Alias: DrPainMD
Loc: NB, Canada
DrPainMD's Avatar
User: #6014
Since: Jan 2007
DrPainMD is offline
Thumbs up Re: Setting Up Your Home Theater 101
July 10, 2007
Added:
General
Home Theater Shack - Glossary of Words, Phrases and Acronyms for Home Theater, Audio, Video, Electronics and Forums
Old 07-24-07, 10:34 AM   #6 (Link)
Alias: DrPainMD
Loc: NB, Canada
DrPainMD's Avatar
User: #6014
Since: Jan 2007
DrPainMD is offline
July 24, 2007
Added:
Audioholics - Whole House Wiring Basics, Part 4
Old 03-23-08, 01:46 PM   #7 (Link)
New Member
Alias: cbose
Loc: CHICAGO
User: #18631
Since: Mar 2008
chuck bosley is offline
Thanks for the info. I am close to purchasing my first system. I need advice from the members though. I am looking at a Mitsubishi WD68533 tv with a Yamaha RX v1800 and Focal SIBSYSB speakers. I've been trying to research and find reviews on these products. My main concern is about the Yamaha RX v1800 - I have found a Yamaha RX v2700 for close to $500.00 less and wonder if the 2700 is a better receiver. Any thoughts or comments from anyone in regards to the products I've mentioned? Thanks! Chuck
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
Similar Threads
Bill's Home Theater Ramius Home Theater Gallery 12 04-07-07 05:17 PM
Need help with setting up home theatre components eternity System Setup and Connection 1 02-01-07 09:01 PM
Home Theater for a Higher Cause Wayde Home Theater, Audio and Video News 0 08-11-06 12:50 AM
Valorums home theater Valorum Home Theater Equipment 2 05-18-06 12:17 PM
Home Theater vs Movie Theater Roger Home Theater, Audio and Video News 0 05-09-06 07:45 PM
Mach 5 Audio
