| System Setup and Connection Equalizer & Accurian 5.1 Home Theater ReceiverDiscuss Equalizer & Accurian 5.1 Home Theater Receiver in the Home Theater | Audio and Video forum; Equalizer & Accurian 5.1 Home Theater Receiver I've got an Accurian 5.1 channel surround Stereo Receiver and a Kenwood 1070KE Stereo Graphic Equalizer. The whole problem is, ... |
| | #1 (Link) | |||
| Equalizer & Accurian 5.1 Home Theater Receiver I've got an Accurian 5.1 channel surround Stereo Receiver and a Kenwood 1070KE Stereo Graphic Equalizer. The whole problem is, the Accurian 5.1 receiver does not have a "Tape Monitor" button/switch so any effects the Equalizer creates for room acoustics, it never reaches the loudspeakers. Is there any way known to man, around this, other than getting a two channel Stereo receiver. Also I just got a vintage pair of JBL L56 speaker/montiors at the pawn shop. They wanted $80.00, and I was willing to pay it, but I noticed a couple problems. One of the pair didnt work and there was a rattle inside when we brought it up to the counter. The same one, part of the Woofer Surround (Butyle Rubber) had a slit in it. I got a discount for the slit surround and then got the pair for $37.00 when he noticed one of the pair didnt work, at all. I got home, cleaned themm up, removed the 10" Woofer and found a .068uf =/-20% capacitor blown apart. The rattle was one of the coils broke away from the Cross-over PC board. Anyway, they're all fixed and sound great! | |||
| | #2 (Link) | |||
| | Re: Equalizer & Accurian 5.1 Home Theater Receiver James, Even if there was a tape monitor loop to connect the equalizer, it wouldn’t do you much good. With the tape monitor engaged, you only get Dolby Pro-Logic, not Dolby Digital, since the tape loop is an analog signal path. So, you’d be missing out on the discrete 5.1 audio for DVD and HD broadcasts. The only “work-around” is if your receiver has both pre-out and main-in jacks. If not, you have to use an outboard amp and connect the EQ between it and the receiver’s pre-out jacks. Congrats on the JBL fix. You can do a “band aid” on the woofer with the split surround, too. Just spread a thin layer of silicone across it, but on the back side. Once it sets up, it should hold everything together and be practically invisible from the front. Regards, Wayne | |||
| | #3 (Link) | |||
| Re: Equalizer & Accurian 5.1 Home Theater Receiver Thanks for the reply Wayne, yeah I've already put the band-aid on the woofer, and they sound great. As for the Receiver, I'll give it once over tomorrow and see what its got for pre-outs, etc. Thanks again man, appreciate it! | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| My little Home Theater | JRace | Home Theater Equipment | 2 | 06-06-07 04:42 PM |
| Yamaha Bows New One-Box Surround System (YSP-1100) and Home Theater Receiver (RX-V2700) | Chris Boylan | Home Theater, Audio and Video News | 0 | 10-01-06 12:25 AM |
| Secrets of Home Theater Onix Rocket R-DES Equalizer review | geekwithfamily | BFD Forum | 1 | 09-14-06 02:57 PM |
| Pre/pro + Amp or all-in-on receiver? | haver | Home Theater Components | 21 | 07-17-06 11:30 AM |
| Home Theater vs Movie Theater | Roger | Home Theater, Audio and Video News | 0 | 05-09-06 07:45 PM |
