| Home Theater System Recommendations Advice on HT system for around $1500Discuss Advice on HT system for around $1500 in the Home Theater | Audio and Video forum; Advice on HT system for around $1500 Hi all,
This is my first post here. I know this is a question repeated many times but I have ... |
| | #1 (Link) | |||
| Advice on HT system for around $1500 Hi all, This is my first post here. I know this is a question repeated many times but I have a few HDMI questions as well. This will go with a Samsung 52" with the 120Hz refresh and a Toshiba a30(Hd-Dvd). It is my understanding that I need to get a receiver with version 1.3a with deep color support and capable of 120Hz. I have also read that some of the receivers have lip sync issues with the new hd audio formats(TrueHd etc.). I would also like to have a component signal (Wii) going into the receiver and going out the single HDMI out. Been looking at Yamaha, Denon, Onkyo and Pioneer Elite models. The second part of the question is speaker related. Looking for a good bookshelf size system for a room around 30x25. Would like to stay in the $1500 range but could be convinced to go a bit higher for the entire system. Are some of my concerns about the receiver valid ones or just another way for the industry to get more money from me. Thanks for any advice on the matter and my apologies for any breach of forum protocol. Thanks | |||
| | #2 (Link) | |||||
| Re: Advice on HT system for around $1500 Quote:
Yes this is the best way to go but dont worry about the 120hz support. Quote:
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||||
| | #3 (Link) | |||
| | Re: Advice on HT system for around $1500 I agree that the Onkyo 805 should do you well. It seems to be very popular and has about all the features you could ask for... as well as appears to be the least expensive of all the options. On bookshelf speakers, the first place I'd look is to SVSound and their new MBS-01 (Pictures) speakers. That might run you a little tight on the budget. There are a host of good speakers out there to choose from. Paradigm would probably fall within your range and are very popular. Do you have anywhere you can listen to speakers? | |||
| | #4 (Link) | |||
| Re: Advice on HT system for around $1500 Thanks for the advice guys! The 805 was at the top of the list but heat issues had me checking other options. I do have a few good places to listen to some speakers. One place does sell Paradigm and I have heard them. Nice speakers. Would like to listen to the SVSound speakers but haven't checked for a location yet(if there is B&M). Thanks again for the advice. The 805 is definately cheaper than the others. | |||
| | #5 (Link) | |||
| Re: Advice on HT system for around $1500 The receiver $595.00 Denon AVR-2308CI, from........ http://www.dbuys.com/product/?47711&...rt_id=21560780 The 5.1 Surround Sound Speakers with PB12-NSD for $1,149 + shipping....... https://svsound.com/products-sys-sbs_black.cfm Thats more then your budget but This would be a nice system. I have the SBS-01 with an old pioneer receiver and they sound pretty good , for bookshelves they are awesome![]() For the technical questions I let the pros answer that ![]() My 2cents!! ![]() | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Speaker quest (listening reviews included) | Funkmonkey | Home Audio Speakers | 101 | 06-23-08 05:45 PM |
| $1500 budget and looking for help | Devil_909 | Home Audio Speakers | 29 | 12-28-07 04:31 AM |
| Question and advice: Best home theater system for 1200-1800 | pricegd2 | Home Theater System Recommendations | 16 | 09-11-07 08:04 PM |
| Behringer EP 1500 / EP 2500 Pro Amps Measured | Jerm357 | DIY Subwoofers | 0 | 06-12-07 08:03 AM |
| Would like your advice on a system I'm thinking of putting together | olivestreetprods | Home Theater System Recommendations | 0 | 03-04-07 10:10 PM |
