| Home Theater Systems 96 vs. 48 hz ???Discuss 96 vs. 48 hz ??? in the Home Theater | Audio and Video forum; 96 vs. 48 hz ??? I have the Onkyo HT-S894 system and the DVD player won't let me change to 96 hz. Isn't this better ... |
| | #2 (Link) | |||
| Re: 96 vs. 48 hz ??? Marketing folks would have you believe so. 48 will sound identical with a DVD soundtrack. If you get into SACD, you might find a difference. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #4 (Link) | ||||
| Re: 96 vs. 48 hz ??? Quote:
-Chris | ||||
| | #5 (Link) | |||
| Re: 96 vs. 48 hz ??? 96kHz upsampling allows for better mathematical/electrical manipulation. Since your electronics are doing things to the signal, this can help. For example, introduced jitter might be lower at 96kHz than at 44.1/48kHz. You can see the effects of sampling frequency listed in the data sheets of various audio components. SACD uses a completely different ADC algorithm than Red Book, which is where its claimed better audio quality comes from. It uses the same algorithm, Delta-Sigma, used by the majority of high quality DACs on the market today. From Wikipedia: "The principle of the [Delta-Sigma] architecture is to make rough evaluations of the signal, to measure the error, integrate it and then compensate for that error." So given good gear, you should hear a more accurate representation of the original music because you don't have the quantization issues of 16-bit PCM. Which is why you only find SACD for jazz and classical and other similar types of music. ![]() | |||
| | #7 (Link) | |||
| Re: 96 vs. 48 hz ??? The setting on your dvd player is probably asking you if you want it to downsample a 96khz bitstream to 48khz before sending it out your digital connection. Some early receivers could not decode a 96khz pcm signal so it had to be downsampled in the dvd player first. Not sure why your player won't allow you to make the switch. How is it connected? I do know that most 96khz recordings are protected heavily. Does it have HDMI? Maybe it has to be connected this way to work?? As for 48vs96 with dts movies... not all dts movies are encoded in this higher quality format, but if they are and your receiver can decode it then it takes place automatically. If it cannot, it is fully backwards compatible and will work without have to change settings anywhere. | |||
| | #8 (Link) | |||
| Re: 96 vs. 48 hz ??? Thanks! It is hooked up via HDMI. What's odd to me is that if something usually is not an option, that option will be "gray" and not even allow you to choose it. This is letting me select that option but when I try to enter it, it does nothing. | |||
| | #10 (Link) | |||
| Re: 96 vs. 48 hz ??? And I bet for the ones that sound better, most of the difference is that they were remastered, not the higher sampling rate. But, if getting the better master can only be done by SACD, then yes, SACD offer an improvement, but don't instantly chalk it up to 96k. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #11 (Link) | |||
| Re: 96 vs. 48 hz ??? Unless the source is recorded in 96khz I see no difference in taking 48Khz and upsampling to 96, especially if it is a very well done recording. IMO a TrueHD/PCM track in 48kHz/24bit is far better then a DD+ track at 96kHz/24bit. Cheers Bobby | |||
| | #12 (Link) | |||
| Re: 96 vs. 48 hz ??? Telarc is the only company I'm really aware of that does their studio recording specifically with the intention of creating high quality discs, both SACD and Red Book. It doesn't do any good to take something originally done for PCM and then just stick it on SACD to get a multi-channel mix. I'm also going to guess fibreKid has at least some decent gear to hear the difference, but you'd really want some good gear to clearly hear differences. I don't think I would be able to hear much difference on say an $800 receiver and $1500 speakers, but move to a $3k pre-pro and $8k speakers and it's a new experience. (Retail prices.) | |||
| | #13 (Link) | |||||
Any properly dithered 16 bit recording and/or properly dithered system or properly dithered down-sampled signal will not exhibit quantization artifacts of significance. Actual quantization error noise is a rare thing to encounter in modern (gear newer than 20 years old) audio gear. The main difference of potential audibility is the quality of re-sample algorithm used. A poor one can result in high amplitude ripple and/or a high level of aliasing artifacts contaminating the DAC output. A good re-sampling algorithm will be measure virtually perfect and have no audible consequence. Now, what is the statistical trend for 'quality' re-sample algorithms in any particular price class? I don't know if a significant trend is present, or how many are possibly audibly different; I am basing this on the computer sound card market. In the computer sound card market, poor re-sampling algorithms are usually only found on the cheapest/lowest quality products. But today, even lower price products in this realm have high quality re-sampling systems. -Chris | |||||
| | #14 (Link) | ||||
-Chris | ||||
