Yamaha or Onkyo? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater System Recommendations
Yamaha or Onkyo?
Discuss Yamaha or Onkyo? in the Home Theater | Audio and Video forum; Yamaha or Onkyo? Hi had a look at Yamaha RX - V1700 and Onkyo TX SR 605.. found both grt... can some one ...
Old 03-11-08, 01:58 AM   #1 (Link)
New Member
Alias: count
Loc: Mumbai
User: #18001
Since: Mar 2008
countdraks is offline
Yamaha or Onkyo?
Hi
can some one guide me which one to look at.. completely for home use...
also .. any other suggestion for other products will be welcome
Thanks
Old 03-11-08, 02:34 AM   #2 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: Yamaha or Onkyo?
Welcome to the Shack!
Both of those are very capable receivers, but the Onkyo is going to have the latest features. The best thing to do will be to decide which features you need most.
What all do you need and how much can you spend for everything?
Old 03-11-08, 02:49 AM   #3 (Link)
Alias: Jerome
Loc: Norway
jerome's Avatar
User: #8468
Since: Apr 2007
jerome is offline
If you're going to compare the new Onkyo to Yamaha then you should compare it to the RX-V1800, not the 1700.
Is there any reason why you do not consider Pioneer, Denon, or any other well known receiver?
Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Denon DVD-2930 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100"
Old 03-11-08, 03:14 AM   #4 (Link)
New Member
Alias: count
Loc: Mumbai
User: #18001
Since: Mar 2008
thanks for teh update..
was having a look at denon 1708...any other in denon??. which pioneer model do you suggest?
Old 03-11-08, 05:28 AM   #5 (Link)
New Member
Alias: count
Loc: Mumbai
User: #18001
Since: Mar 2008
hi.. pretty new to the world of hi end systems... looking to spend max $2000 on av receiver and speaker package.. have LCD Sony S Series - KLV-40S200A/B...
what do u suggest for av and speakers?
Old 03-11-08, 06:00 AM   #6 (Link)
Alias: Jerome
Loc: Norway
jerome's Avatar
User: #8468
Since: Apr 2007
jerome is offline
If I were you, I would buy a receiver of the new generation with support for HD sound, HDMI 1.3. They sound much better than the older ones, especially for Yamaha.
You should also try to buy the best you can afford. Look at Audiogon for used speakers and/or receivers. You will be able to save a great deal of money compared to buying everything brand new.
I recommend Yamaha, Onkyo and Pioneer over the other brands. But that's MY recommendation. Yamaha has the best sound if you're mostly interested in movies. Onkyo probably has the best sound for 2-channel music. Pioneer is very good at doing everything
Sonnie: any recommendation for a $2000 package ?
Old 03-11-08, 09:35 AM   #7 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
The Onkyo TX SR805 for $800
SVS SBS-01 speaker package including a sub for $1200
This will give you the best bang for buck.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 03-11-08, 09:55 AM   #8 (Link)
Loc: Lower Alabama
Sonnie is offline
Yep... I would say that is a very good system recommendation there. I have the 805 myself paired with Ascend Acoustics, which is another good speaker system to consider, but a little more expensive.
Old 03-11-08, 10:45 AM   #9 (Link)
Alias: Jerome
Loc: Norway
jerome's Avatar
User: #8468
Since: Apr 2007
jerome is offline
I agree. I have never heard them but read very good reviews both for the receiver and the speakers.
And it's easy to upgrade with another sub when you get the cash
Old 03-15-08, 01:27 AM   #10 (Link)
New Member
Alias: count
Loc: Mumbai
User: #18001
Since: Mar 2008
tks for the input guys....
narrowed down to Onkyo TX-SR705, Denon AVR-3805, Pioneer Elite VSX-82TXS
shud be finalising by next weekend.. but leaning towards Onkyo
thanks
Old 03-17-08, 09:06 PM   #11 (Link)
Alias: Jim
Loc: Cibolo, Texas
Zembonez's Avatar
User: #18335
Since: Mar 2008
Zembonez is offline
I recommend the Denon. Never owned an Onkyo surround unit (understand they are quite good), but my Yamaha experiences were less than satisfactory from a musical point of view. I have a Denon AVR-3806 right now and I love it both sonically and as a surround unit.
Zembonez "always evolving" HT / Denon AVR 3806 / Denon DVD-1920 / 2 Adcom GFA 545 II / Adcom GFA 535 II / Adcom ACE 515 Line Conditioner / 4 Vintage Advent 6003 / 2 Sonance S624T / Opt Pro Linaeum Center - 2 Image Dynamics DVC 12 Subs / 4 Layer Laminated Custom MDF Enclosure / Kimber & Grayson Interconnects / AudioQuest Cables / Vintage Sony PS-3750 TT / Grado Prestige Silver / Lots of vinyl / Way too many DVDs and CDs / Etc.
Old 03-18-08, 02:09 AM   #12 (Link)
Alias: Jerome
Loc: Norway
jerome's Avatar
User: #8468
Since: Apr 2007
jerome is offline
Well, like for most of the AV equipment, it's all a matter of taste. Many people like the Denon sound, other like the Yamaha/Pioneer sound.
I had the Denon 3806 receiver and liked it but I must admit that the Yamaha sound fits me better now.
In my opinion, the most important is to listen before buying!
As long as you like what you buy and it fits your taste then you're good!
Old 03-18-08, 08:25 AM   #13 (Link)
Alias: Jim
Loc: Cibolo, Texas
Zembonez's Avatar
User: #18335
Since: Mar 2008
Zembonez is offline
jerome wrote: View Post
You are absolutely right. My post was simply my opinion of my particular installation.. A lot more goes into the overall sound of a system also. Speakers, cables, interconnects are all a factor.
Buy something you like and most of all... USE IT!
Jim
« Home Theater Shack > Home Theater | Audio and Video > Home Theater System Recommendations »
Similar Threads
Yamaha RSXV1700 vs Onkyo 805 vs Onkyo 705 Buckster Home Theater Components 2 03-03-08 09:22 AM
Onkyo TX-SR305? mifydnu Home Theater Components 3 11-09-07 12:08 PM
HK or Onkyo brandonnash Home Theater Components 14 06-03-07 12:02 AM
Onkyo lcaillo Manufacturer and Vendor Reference Information 0 05-12-07 10:17 PM
Oppo dv-970HD, Yamaha DVD-S-657, or Yamaha DVD-S1500 nm2285 Home Theater Components 6 10-31-06 12:02 PM
Mach 5 Audio
