mitsubishi wt-42311 sound and no picture - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Manufacturers Service and Support
Discuss mitsubishi wt-42311 sound and no picture in the Home Theater | Audio and Video forum; mitsubishi wt-42311 sound and no picture I have a Mitsubishi wt-42311 I get the flashing code 2-1 like 3 or 4 times after holding the buttons ...
Old 04-03-08, 11:11 PM   #1 (Link)
New Member
Alias: Rob
User: #19135
Since: Apr 2008
frogwood is offline
I have a Mitsubishi wt-42311 I get the flashing code 2-1 like 3 or 4 times after holding the buttons for 5 or so seconds what does this mean?I was having a problem with the picture zooming in and out some times but it was really sporadic.Then I hooked up a coax cable and herd a bunch of weird sounds when I turned the tv on then nothing no more picture just sound any ideas?
Old 04-04-08, 05:18 AM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is online now
Re: mitsubishi wt-42311 sound and no picture
Are you sure that the code is 2-1 and not 1-2? 2-1 is X-ray protection, likely a failure in the high voltage reference or regulation circuits. I would suggest having a skilled tech service these kinds of problems. 1-2 indicates that the set did not shut down due to a problem that is monitored by the protection circuits.
When you say the picture was zooming in and out, do you get poorer focus or convergence when this happens? Do the sides get curved? What degree of zooming do you get?
Your duplicate post in another thread was deleted. Please post only once.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 04-04-08, 08:11 AM   #3 (Link)
New Member
Alias: Rob
User: #19135
Since: Apr 2008
frogwood is offline
It is in fact 1-2 it blinks for 5 sets.As far as the zooming the picture would also get all distorted and out of focus while the zooming was happening.I'm not sure about the sides being curved it would do it pretty quickly(the zooming in and out) then the tv would shut off.Turn the tv back on and it was usually fine.Some times the tv was on for a few hours and was fine and some times it could be on for 5 minutes and do it.
Old 04-04-08, 01:14 PM   #4 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
Is the picture out of convergence or out of focus when this happens? Big difference in terms of diagnosis.
-Joseph Joubert
Raise the bar.
Old 04-04-08, 01:52 PM   #5 (Link)
New Member
Alias: Rob
User: #19135
Since: Apr 2008
frogwood is offline
I don't understand what you mean exactly.
Old 04-04-08, 02:40 PM   #6 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
Convergence is the alignment of the three colors, red, green, and blue and is effected electronically by correction waveforms applied to the convergence yokes to electromagnetically alter the position and shape of the electron beam. Focus is how well the beam is controlled to provide the smallest spot size at the phosphor as the beam scans. It is effected electrostatically with high voltage in the CRT and also optically in the lenses.
If you have a convergence problem the fix is likely easy to DIY. If you have a focus problem it may require a tech with experience and the right equipment.
-Joseph Joubert
Raise the bar.
Old 04-04-08, 05:21 PM   #7 (Link)
New Member
Alias: Rob
User: #19135
Since: Apr 2008
frogwood is offline
ok I kinda get what you are saying.Well now that you mention the color thing when the picture was zooming it did get a lot more red than normal.How would I go about trying to fix this problem?
Old 04-04-08, 10:41 PM   #8 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
Without a better description of the problem, there is no way to diagnose it. Sounds like you are beyond your DIY capability and you need to find an experienced Mits tech.
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support »
Similar Threads
Need help getting an HD picture on my TV psantovena Video Displays and Processors 3 12-02-07 12:36 AM
mitsubishi 1080hd sound but no picture - how to fix? osprey24 Manufacturers Service and Support 6 09-05-07 07:03 AM
Mitsubishi HD 1080 No Picture Breeze4u Manufacturers Service and Support 6 03-04-07 09:17 PM
Smart House Australia Plagiarizes Big Picture Big Sound Article on Sharp LCD HDTV Chris Boylan Home Theater, Audio and Video News 2 09-22-06 05:38 PM
Mach 5 Audio
