Mitsubishi vs-50805 issue - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Manufacturers Service and Support
Discuss Mitsubishi vs-50805 issue in the Home Theater | Audio and Video forum; Mitsubishi vs-50805 issue I have a Mits (built in 2000) model:vs-50805 series:HD1080 that is exhibiting the following issue. After pressing the power button, ...
Old 04-16-08, 02:05 PM   #1 (Link)
New Member
Alias: kserdar
Loc: Houston
User: #19677
Since: Apr 2008
kserdar is offline
I have a Mits (built in 2000) model:vs-50805 series:HD1080 that is exhibiting the following issue. After pressing the power button, the timer LED will light for about 3 seconds, the screen will show all green and then the set will power down. I have been reading about other Mits sets that have similar problems ... check the caps on the DM board. The 50805 does not have this separate metal box (on the left).
First questions - Does my set have a DM board? Where is it located? How many caps am I looking for? Is this a known issue with this model?
While looking for coolent leaks, I noticed this transistor sparking(see picture). Upper right corner is showing arcs.
Second questions: How do I remove this board? Is this a sign of other failures?
Anything else I should know about the TV?
Thanks
Old 04-16-08, 03:31 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Re: Mitsubishi vs-50805 issue
There is no DM in this set. It is pre-digital. There should be no arcing. This needs to be dealt with before you damage something else.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 04-16-08, 04:32 PM   #3 (Link)
New Member
Alias: kserdar
Loc: Houston
User: #19677
Since: Apr 2008
kserdar is offline
lcaillo wrote: View Post
I agree about the arcing. So - I wil ask again... How do I remove the board? It appears to have "glue" locking the parts together. I have the skills to repair the board. I just don't want to break anything removing the board.
Old 04-17-08, 01:58 PM   #4 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
There is glue holding the connector to the base of the CRT. There is also a screw locking the bracket. Lossen the screw, slice the glue with a knife and it unplugs. Be VERY careful working with a CRT. There may be a charge on the tube or the components on the board and you can break the pins or the CRT.
-Joseph Joubert
Raise the bar.
Old 04-17-08, 02:43 PM   #5 (Link)
Alias: Krankshaft
User: #19570
Since: Apr 2008
Krankshaft is offline
After removing the board set your DMM to diode check and check the transistor for shorts.
I believe the transistor you're pointing to is the color signal amp for that tube.
Also check those green (wire wound I believe) resistors on the board.
The glue is put there so that the board doesn't disconnect or loosen from the tube during shipping.
Old 05-07-08, 04:16 PM   #6 (Link)
New Member
Alias: kserdar
Loc: Houston
User: #19677
Since: Apr 2008
kserdar is offline
The transistor checked out bad. I have replaced it and now the set works OK.
Thanks for all the help.
« Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support »
Similar Threads
HDMI and Audio Issue PhotoByMark System Setup and Connection 6 03-01-08 11:09 PM
MITS VS-50805 Problem JVP Manufacturers Service and Support 13 01-29-08 05:23 AM
Mits VS-50805 problem SAMMY18 Manufacturers Service and Support 1 08-09-07 05:37 AM
Mitsubishi VS-50805 colors are out of alignment kerbking Manufacturers Service and Support 3 07-24-07 10:13 PM
mits VS-50805 Green shadowing after power interruption bwinters Manufacturers Service and Support 5 06-28-07 08:58 PM
Mach 5 Audio
