Sony VPH-G70 Convergence problem??? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Manufacturers Service and Support
Discuss Sony VPH-G70 Convergence problem??? in the Home Theater | Audio and Video forum; Sony VPH-G70 Convergence problem??? I have taken 2 pictures of the screen (projector has not yet been correctly setup). Pic 1 was taken just ...
Old 04-27-08, 10:18 PM   #1 (Link)
New Member
Alias: andrew
Loc: Brisbane, Australia
User: #20121
Since: Apr 2008
countryhick is offline
I have taken 2 pictures of the screen (projector has not yet been correctly setup). Pic 1 was taken just after turn on, Pic 2 was taken 30mins later.
What do you guys think? Does it look like replacing the convergence IC's will cure my problem?
Regards Andrew
Old 04-28-08, 05:28 AM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Re: Sony VPH-G70 Convergence problem???
Could be a bad solder connection from what you show here. Can you adjust it after warm-up?
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 04-28-08, 04:08 PM   #3 (Link)
New Member
Alias: andrew
User: #20121
Since: Apr 2008
lcaillo wrote: View Post
Yes, I can adjust it after warm-up, but it will drift and change its position just about every time I turn the unit on. I did pull out the "DC" (convergence board) and re solder lots of joints even though they appeared to look fine. Any ideas would be greatly appreciated.
Cheers Andrew
Old 04-28-08, 06:32 PM   #4 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
If you can adjust it the output stage is likely OK. More likely you have a bad related part such as a cap of op amp in the convergence generator causing drift. It would take some troubleshooting to know.
-Joseph Joubert
Raise the bar.
Old 04-28-08, 06:36 PM   #5 (Link)
New Member
Alias: andrew
User: #20121
Since: Apr 2008
Lcaillo, I just re tested the unit to double check I could adjust the cent centering of the red gun. I can adjust it up and down but not left or right. Sorry about the miss information.
Old 04-28-08, 07:08 PM   #6 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
If you cannot adjust it the most likely problem is a bad output.
-Joseph Joubert
Raise the bar.
Old 04-28-08, 07:12 PM   #7 (Link)
New Member
Alias: andrew
User: #20121
Since: Apr 2008
Thank-you. I have read your convergence repair thread and would like to know if the STK392-220's have a super-seeded IC?
Old 04-28-08, 08:55 PM   #8 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
Not that I am aware of. I would ask about this set on the CRT forum at AVS where you are likely to find people with more experience with it. I never see these, so I can only be of generic assistance with it.
-Joseph Joubert
Raise the bar.
Old 04-29-08, 02:35 PM   #9 (Link)
Alias: Krankshaft
User: #19570
Since: Apr 2008
Krankshaft is offline
Also don't forget to check the metal film resistors around the convergence ICs since in some cases a bad output can take one of these down with it as well.
If an upgrade doesn't exist now for your STK it probably never will since Sanyo discontinued these ICs in 06.
There are more than enough in the supply chain for years to come though.
Due to lack of demend due to the price drop of DLP, LCD and Plasmas on the market which can't hold a candle to CRT in terms of contrast ratio.
Old 05-19-08, 07:10 PM   #10 (Link)
New Member
Alias: andrew
User: #20121
Since: Apr 2008
OK. I have replaced the convergence IC's (from B&D ENTERPRISES) I also checked all the resistors with a DMM and cross checked them with the schematics I have for the projector. I'm still faced with the same problem. With all adjustments reset, the red beam is still playing up. I can adjust the red beam up and down but not left or right.
I'm still keen to pursue the problem so if anyone has suggestions please post them.
Cheers Andrew
Old 05-19-08, 07:38 PM   #11 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
My guess would be that you missed something. Could be in the convergence generator as well...time to get out a scope and check the signals from the CG to the ICs.
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support »
Similar Threads
Hitachi model #43fdxo1b convergence problem Need Help!!! Gmacinhimer Video Displays and Processors 1 04-23-08 07:19 PM
Hitachi 61SWX10B - Convergence Problem JingoV Manufacturers Service and Support 2 03-19-08 02:04 PM
Convergence Problem??? trgovic Manufacturers Service and Support 7 12-27-07 05:55 PM
philips ic convergence problem help kuby71 Manufacturers Service and Support 0 10-19-07 03:48 PM
Hitachi Ultrascan HD Convergence Problem kc7brown Video Displays and Processors 3 07-23-07 08:10 PM
Mach 5 Audio
