Jvc Av-65wp74 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Manufacturers Service and Support
Jvc Av-65wp74
Discuss Jvc Av-65wp74 in the Home Theater | Audio and Video forum; Jvc Av-65wp74 I just had two STK's in my JVC model AV-65WP74 replaced. This corrected the convergence problem (3D images) but after ...
Old 05-12-08, 01:01 PM   #1 (Link)
New Member
Alias: mathemajikian
User: #20668
Since: May 2008
mathemajikian is offline
Jvc Av-65wp74
I just had two STK's in my JVC model AV-65WP74 replaced. This corrected the convergence problem (3D images) but after the repair man left I noticed a thin horizontal line almost in the shape of a smile going across the middle of the screen. It seems to be made up of three colors and is most visible when the T.V is displaying a white background. Like on a persons face I can see a thin line of three colors. I can't really see it on black/grey backgrounds. All the lines seem to be lined up on the convergence grid. Any ideas as to what could be causing this problem?
Old 05-12-08, 01:12 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Re: Jvc Av-65wp74
Can you post an image? Not sure what this might be.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 05-12-08, 02:40 PM   #3 (Link)
New Member
User: #20668
Since: May 2008
Re: Jvc Av-65wp74
Here's the STK chips I had the repairman replace the faulty ones with: http://cgi.ebay.com/ws/eBayISAPI.dll...STRK:MERFB:IID
Hopefully they weren't some cheap copies which might be causing this problem. Here's two pics. You can see the small rainbow like lines if you look closely.
Old 05-12-08, 02:55 PM   #4 (Link)
New Member
User: #20668
Since: May 2008
Re: Jvc Av-65wp74
Also the lines are really three small curved lines. One red, one green, and one blue. Almost looks like the lenses aren't projecting off the mirror in the back right? This thread kinda states the problem I'm seeing with the lines: http://www.fixya.com/support/t186581-three_curved_lines
Old 05-12-08, 02:55 PM   #5 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
Re: Jvc Av-65wp74
Yes, they probably are cheap copies.
How long was the set operating with a convergence problem? You may have slightly burned the tubes. Could also be some slight linearity problem in the convergence that can be adjusted out. It would take examination of full field red, green, blue test patterns and a convergence grid to determine.
-Joseph Joubert
Raise the bar.
Old 05-12-08, 03:04 PM   #6 (Link)
New Member
User: #20668
Since: May 2008
Re: Jvc Av-65wp74
It ran with the convergence problem for about a month. Could that have caused this? It looks like a rainbow curve right in the center of the screen.
Old 05-12-08, 03:06 PM   #7 (Link)
New Member
User: #20668
Since: May 2008
Re: Jvc Av-65wp74
How can I do this?
Old 05-12-08, 03:23 PM   #8 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
Re: Jvc Av-65wp74
mathemajikian wrote: View Post
You may have burned the CRTs. Like I said, you need the test patterns that I described to test further. Get a test disc like AVIA or DVE.
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support »
Similar Threads
Jvc Av-65wp74 kg2k Manufacturers Service and Support 6 06-18-08 08:19 PM
New JVC goodness bluejay Video Displays and Processors 9 03-30-08 07:51 AM
JVC RS-1 in Sacramento otorabian Home Theater Projectors 4 08-26-07 03:40 PM
JVC RS1 jagman Home Theater Projectors 24 07-01-07 04:58 PM
JVC lcaillo Manufacturer and Vendor Reference Information 0 05-14-07 07:11 PM
Mach 5 Audio
