Mitsubishi VS-50805 Color Issue - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Manufacturers Service and Support
Discuss Mitsubishi VS-50805 Color Issue in the Home Theater | Audio and Video forum; Mitsubishi VS-50805 Color Issue Our set, purchased in 2000, shows vivid yellow and purple/blue colors, but reds and greens show up as a kind ...
Old 05-14-08, 10:12 PM   #1 (Link)
New Member
Alias: Bill
Loc: Colleyville, TX
User: #20770
Since: May 2008
bcranes is offline
Our set, purchased in 2000, shows vivid yellow and purple/blue colors, but reds and greens show up as a kind of "brown and white". Could use advice and/or service referral in D/FW area.
Old 05-15-08, 05:32 AM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Re: Mitsubishi VS-50805 Color Issue
What does it look like if you turn the color all the way down? What color is what should be black and white?
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 05-15-08, 08:55 AM   #3 (Link)
New Member
Alias: Bill
User: #20770
Since: May 2008
bcranes is offline
It displays black and white. Thanks for your help here.
Old 05-15-08, 10:56 AM   #4 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
Can you post an image of the effect?
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support »
Similar Threads
Another Mitsubishi vs-50805 issue kserdar Manufacturers Service and Support 5 05-13-08 03:09 PM
Mitsubishi vs-50805 issue kserdar Manufacturers Service and Support 5 05-07-08 04:16 PM
Mitsubishi Convergence issue RaiderRC Video Displays and Processors 20 04-26-08 09:01 AM
Mitsubishi VS-50805 colors are out of alignment kerbking Manufacturers Service and Support 3 07-24-07 10:13 PM
Mach 5 Audio
