Mitsu convergence question... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Service and Support > Brand Specific Service Forums > Brand Specific Service Forums > Mitsubishi
Mitsubishi
Discuss Mitsu convergence question... in the Brand Specific Service Forums forum; Mitsu convergence question... Hi, I have 2 quick questions for you. 1.) I have a Mitsu WS-65807 s/n 112297. I had the bowtie ...
Old 05-28-07, 02:37 PM   #1 (Link)
New Member
Alias: Chad
Loc: Wyoming, MN
User: #9231
Since: May 2007
  MOBILE is offline
1.) I have a Mitsu WS-65807 s/n 112297. I had the bowtie effect 6 months ago and found the lead on the STK392-570 came off the chip itself. I attempted to tack it back on the chip, and resoldered all the connections on the board for both chips. Now the problem is back and I would like to replace both chips since they are 7 years old. I have seen you talk about advanced convergence adjusting needed after replacing these chips. Is this in need of a service manual for tweaking or just advanced setup in the comsumer menu adjustments? I have spents hours in the normal menu adjusting convergence previously and it came out great, but I have not replaced these chips before. Don't want to mess it up without proper instructions. The IC's are both STK392-570 but one says D3D23 and the other says D3D25, are these date codes or differences in the chip?
2.) 4 years ago under warranty, a tech came out and fixed a similar problem. I was not home and wish I could have seen what he did. The TV had a convergence issue, however it was not "bowtieing". The 3 colors were all spaced apart about a 1/4" or so, evenly shadowing each other. Was this the same IC issues? My wife said he soldered something in out of his truck and the TV has worked great until 6 months ago.
Thanks a million, this forum is Great!!
Chad
Old 05-28-07, 03:51 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: Mitsu convergence question...
The tech probably soldered the chips ar the circuit board. Sometimes the solder at the base of the chip fails as well, as you experienced. The 5 characters on the chip are a date code for the batch of chips. Make sure that you get the original Sanyo parts. Use B&D, Acme, or TriTronics (but do not use the TT versions which may not be original Sanyo parts). You may be able to do all the correction that you need in the advanced convergence in the consumer menu, but if that does not allow the range, you will need to get in to the service mode.
______________________
Why I support scouting...
Core values taught in Cub Scouts:
Citizenship, Compassion, Cooperation, Courage, Faith, Health and Fitness, Honesty, Perseverance,
Positive attitude, Resourcefulness, Respect, Responsibility.
Old 05-28-07, 05:17 PM   #3 (Link)
New Member
Alias: Chad
Loc: Wyoming, MN
User: #9231
Since: May 2007
  MOBILE is offline
Thank you very much. I will get them on order.
Chad
« Home Theater Shack > Service and Support > Brand Specific Service Forums > Brand Specific Service Forums > Mitsubishi »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242
