Mitsubishi WS-65907 Startup Problems - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Service and Support > Brand Specific Service Forums > Brand Specific Service Forums > Mitsubishi
Mitsubishi
Discuss Mitsubishi WS-65907 Startup Problems in the Brand Specific Service Forums forum; Mitsubishi WS-65907 Startup Problems I have a Mitsubishi WS-65907 HDTV which has worked flawlessly since October 2000. It was working fine earlyier today then ...
Old 05-28-07, 12:34 AM   #1 (Link)
New Member
Alias: Ron
Loc: 94070
User: #9218
Since: May 2007
  ronludlow is offline
I have a Mitsubishi WS-65907 HDTV which has worked flawlessly since October 2000. It was working fine earlyier today then tonight I tried to turn it on and the power light came on for 1 or 2 seconds then went off. I unplugged the TV for several minutes, pugged it back in and got the same results. It will not come on with the remote or the button on the TV. Has anyone encountered this problem? I searched the Mitsubishi-TV web site to no avail.
Thanks,
Ron Ludlow
Old 05-28-07, 03:59 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: Mitsubishi WS-65907 Startup Problems
Press Input and Menu buttons simultaneously for 5 seconds, then note the sequice of flashes on the LED. It should be flashing a two digit sequence of 1-2, 2-1, 2-2, 2-3, or 2-4. This may help narrow down the type of railure if the unit is in protect mode.
______________________
Why I support scouting...
Core values taught in Cub Scouts:
Citizenship, Compassion, Cooperation, Courage, Faith, Health and Fitness, Honesty, Perseverance,
Positive attitude, Resourcefulness, Respect, Responsibility.
Old 05-29-07, 09:55 AM   #3 (Link)
New Member
Alias: Ron
Loc: 94070
User: #9218
Since: May 2007
I tried pushing the menu and input (my input button is a rocker type) buttons simultaneously, but the small green power light did not come on at all. Is there another combination of buttons to push?
The green power light still comes on for 1-2 seconds when I push the power button. I tried unplugging the set from the wall electrical outlet for several hours to let any residual electrical buildup dissipate, but it did not help.
Old 05-29-07, 12:30 PM   #4 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
  lcaillo is offline
You have to hold them down together for 5+ seconds. If you do so and get nothing then the set has a problem that keeps the micro from communicating. Sould be something in the PS or reset circuits, or some other circuit keeping the data bus busy. This will require some skilled troubleshooting.
Old 05-29-07, 04:57 PM   #5 (Link)
New Member
Alias: Ron
Loc: 94070
User: #9218
Since: May 2007
Thanks for the suggestions. I have decided to list it on eBay "as is". Hopefully, someone else will be willing to pay for the repairs. I have purchased a new Plasma to replace it
« Home Theater Shack > Service and Support > Brand Specific Service Forums > Brand Specific Service Forums > Mitsubishi »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242
