mitsubishi 1080hd sound but no picture - how to fix? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Manufacturers Service and Support
Discuss mitsubishi 1080hd sound but no picture - how to fix? in the Home Theater | Audio and Video forum; mitsubishi 1080hd sound but no picture - how to fix? I have a mitsubishi 1080hd tv, (older set 8 or so years) over the last few days, it powered itself ...
Old 09-04-07, 10:36 AM   #1 (Link)
New Member
Alias: Mike
Loc: Harrisonburg Virginia
User: #11296
Since: Sep 2007
osprey24 is offline
I have a mitsubishi 1080hd tv, (older set 8 or so years) over the last few days, it powered itself off, and i have on occasion been able to power it back on with a picture, after unplugging from the wall, and it now powers on, but no picture. I have even tried plugging a dvd into the front inputs and still no picture, but sound.
any ideas
thanks
Mike
Old 09-04-07, 04:03 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Re: mitsubishi 1080hd sound but no picture - how to fix?
Post a model number and which types of signals you have tried to view. CAn you see OSD or menus?
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 09-05-07, 06:08 AM   #3 (Link)
New Member
Alias: Mike
User: #11296
Since: Sep 2007
osprey24 is offline
Morning, the Model Number is - WS-65903 - Manufactured Date - December 1999. As to menus or anything on the screen is no video at all, have sound on different inputs, as i have DirectTv, ComCast, and Cd on three different inputs, again with no video at all. Tried a standalone DVD player on the inputs on the front, with same results, sound but no picture.
Old 09-05-07, 06:55 AM   #4 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
This model is well known for coolant leaks.
Read this post very carefully:
http://www.hometheatershack.com/foru...html#post48066
The set in that thread had a leak on the connectors between boards. Your set is more likely to have a leak on the signal board itself. You may have some other problem, but leaks are very common and they can be a challenge for someone who is not experienced with them and thorough.
-Joseph Joubert
Raise the bar.
Old 09-05-07, 06:58 AM   #5 (Link)
New Member
Alias: Mike
User: #11296
Since: Sep 2007
osprey24 is offline
Is this a costly repair??? and should i call only an authorized Mits repair - i live in Harrisonburg Va, 22801 - so only looks like one.
Mike
thanks again
Old 09-05-07, 07:01 AM   #6 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
That depends on whether your available servicers are willing to do this kind of repair like I described. You need to talk to them and find out. If they just want to change boards or are too expensive, you may want to try it yourself. Check with all of the reputable shops in your area, not just the ASCs. The ASC is a good place to start, but Mitubishi is little help on these problems.
-Joseph Joubert
Raise the bar.
Old 09-05-07, 07:03 AM   #7 (Link)
New Member
Alias: Mike
User: #11296
Since: Sep 2007
osprey24 is offline
Will look into this, i was reading the thread yesterday that you mentioned, i will look into this. Thanks again for all your help.
Mike
« Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support »
Similar Threads
How to fix a Cambridge Audio Azur 640C rcarlton HiFi Audio Components 14 04-02-08 12:01 AM
Mitsubishi HD 1080 No Picture Breeze4u Manufacturers Service and Support 6 03-04-07 09:17 PM
Smart House Australia Plagiarizes Big Picture Big Sound Article on Sharp LCD HDTV Chris Boylan Home Theater, Audio and Video News 2 09-22-06 05:38 PM
Whole house audio problem - Easy fix??? Beans 2112 General Discussion 10 07-11-06 12:09 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193
