problems with mitsubishi hd1080 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Manufacturers Service and Support
Discuss problems with mitsubishi hd1080 in the Home Theater | Audio and Video forum; problems with mitsubishi hd1080 Hello, I own mitsubishi hd1080. Recently I am experiancing "mirror picture" - it's all like doubled. Where is the problem? ...
Old 09-11-07, 12:54 PM   #1 (Link)
New Member
Alias: Edas
User: #11477
Since: Sep 2007
edase is offline
Hello,
I own mitsubishi hd1080. Recently I am experiancing "mirror picture" - it's all like doubled. Where is the problem? Would that make any sence to hire a tech to fix it? Maybe it's something pretty simple to work on? Thank you in advance!
Old 09-11-07, 01:29 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Re: problems with mitsubishi hd1080
Read this:
http://www.hometheatershack.com/foru...e-repairs.html
Then post your model number and location for more specific information.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support »
Similar Threads
Mitsubishi HD1080 Power Problem mkravich Manufacturers Service and Support 24 07-05-08 09:57 AM
Mitsubishi HD1080 Edonoso Video Displays and Processors 3 11-17-07 04:07 PM
Mitsubishi HD1080 with shadows Fairlane1965 Manufacturers Service and Support 7 05-19-07 10:05 PM
Mitsubishi HD1080 with shadows Fairlane1965 Home Theater Projectors 2 05-10-07 11:54 AM
Need help w/ Mitsubishi HD1080 set skrochta Manufacturers Service and Support 4 10-25-06 02:26 PM
Mach 5 Audio
