Troubleshooting Question - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Manufacturers Service and Support
Discuss Troubleshooting Question in the Home Theater | Audio and Video forum; Troubleshooting Question I have a Mitsubishi WS-55805 that I bought 7 years ago. I went to turn it on and I got ...
Old 09-14-07, 09:53 PM   #1 (Link)
New Member
Alias: Roger
Loc: Vienna, VA
User: #11566
Since: Sep 2007
beckrog is offline
I have a Mitsubishi WS-55805 that I bought 7 years ago. I went to turn it on and I got some flickering, thin lines & curves that blinked on and off a couple of times and now I have a black screen. Volume doesn't work, can't change the inputs, nothing is happening.
Any ideas what this could be and how much it may cost to fix? I hate to think it's time for a new TV after only 7 years...
Thanks.
Old 09-15-07, 04:15 AM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Re: Troubleshooting Question
Does the set shut down? If so check the diagnostics by pressing input and menu together for 5 sec. on the front panel. You will get a 2 digit blink code on the LED on the front panel. Count the blinks between pauses. If not, do you have menus or OSD?
The thin curved lines tell me that you likely have a convergence or vertical output failure, possibly both. The convergence output amps and the vertical output amp are powered by the same positive supply IIRC and you likely blew a pico fuse on that supply or one of those circuits is pulling it low.
Other possibilities are a coolant leak which you need to check for very carefully or bad capacitors on one of the low voltage supplies.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 09-15-07, 10:13 AM   #3 (Link)
New Member
Alias: Roger
Loc: Vienna, VA
User: #11566
Since: Sep 2007
beckrog is offline
Thanks for the reply. I pushed the input and menu buttons and the light does not blink. I can't access any menus, etc.
Old 09-15-07, 11:33 AM   #4 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
Look for a coolant leak.
Read the thread on the matter very carefully.
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support »
Similar Threads
CD Question Bob_99 Music and DVD Concerts 4 08-29-07 01:48 PM
Question Bob_99 DIY Speakers 12 05-18-07 10:11 AM
Mach 5 Audio
