Coolant Leaks in CRT RPTV - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Equipment Reviews.
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Manufacturers Service and Support > Manufacturers Service and Support > Service and Support
Service and Support
Discuss Coolant Leaks in CRT RPTV in the Manufacturers Service and Support forum; Coolant Leaks in CRT RPTV Various brands have had problems with coolant on the CRTs leaking onto circuit boards, causing lots of strange and frustrating ...
Old 09-15-07, 06:54 AM   #1 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
  lcaillo is online now
Various brands have had problems with coolant on the CRTs leaking onto circuit boards, causing lots of strange and frustrating problems. These repairs can range from easy to impossible, depending on how long the coolant stays on the board, where it went, and how the problem is handled.
The MOST important thing is to properly identify leaks and WHERE the coolant has been on the boards before the boards are moved. If this is done, it can save lots of time locating the problems, and keep the coolant from getting to other locations if the set is not carefully handled. The coolant migrates almost completely, so it takes very careful observation to find its path and source. It may only be a few drops and can end up below chips or even run off of the board to the cabinet. Again, it takes very careful observation to find the path, sometimes. In many cases it is obvious, but many techs have been fooled and missed leaks because they "thought" that they had checked carefully enough.
This is a post that I made specifically regarding a Mitsubishi. It is mostly relevant to coolant leaks in general on any brand and may be helpful advice.
http://www.hometheatershack.com/foru...html#post48066
______________________
Why I support scouting...
Core values taught in Cub Scouts:
Citizenship, Compassion, Cooperation, Courage, Faith, Health and Fitness, Honesty, Perseverance,
Positive attitude, Resourcefulness, Respect, Responsibility.
« Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support > Manufacturers Service and Support > Service and Support »
Similar Threads
CRT based RPTV Convergence Repairs lcaillo Service and Support 207 11-23-08 01:55 AM
CRT owners tbase1 Video Displays and Processors 1 01-24-07 09:18 PM
Good 60+" RPTV for both HDTV and SDTV garycase2001 Home Theater Equipment 2 12-26-06 01:34 AM
FS: Pioneer Elite PRO-510HD 53" RPTV Brian Bunge Classifieds - Video Displays and Projectors 0 12-04-06 01:24 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
