Go Back   Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support
Register
Red fog in Mits ws-65315
Discuss Red fog in Mits ws-65315 in the Home Theater | Audio and Video forum; Red fog in Mits ws-65315 Hi, Hoping you guys here can help. My brother just bought a used ws-65315 and when I helped him set ...
Old 10-12-07, 04:47 PM   #1 (Link)
New Member
Alias: Ken
Loc: Medina,TN
User: #3512
Since: Oct 2006
KenWH is offline
Hi,
Hoping you guys here can help. My brother just bought a used ws-65315 and when I helped him set it up I noticed what I can best describe as a red fog over the top of what should be black background.
For instance when I did the convergence I noticed the red fog behind the on screen prompts only. The rest of the screen is fine...no red fog. It's not at all affected by adjusting the convergence.
I notice it to on high contrast scenes in a movie also. It was a scene where I guy was wearing a bright white shirt and the shirts collar was casting a dark shadow on the shirt. The shadows had a bit of a red foggyness to them.
It was late last night and we were beat when we were doing this so it may be something I can adjust out but the basic controls I tried didn't seem to have any effect on the fog.
The fog's most visible with the green tv generated screen prompts(volume, input, video adjustment, etc) is displayed over a black/dark background. The fog will extend out a few inches in all directions from the lettering of the prompts.
Any ideas what this may be?
Thanks,
Ken
Old 10-12-07, 06:50 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Re: Red fog in Mits ws-65315
Remove the screen and clean the lenses and mirror for starters.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 10-19-07, 09:49 PM   #3 (Link)
New Member
Alias: Ken
Loc: Medina,TN
User: #3512
Since: Oct 2006
KenWH is offline
lcaillo wrote: View Post
Thanks lcaillo,
Tonight I finally had a chance to get back with my brother and work on his tv. Turns out the problem is pretty serious as we found 3 flaws in the red crt's glass. It looks like drops of some kind of liquid etched three small dents in the glass and they vary in size from about 3/8 to 1/2" in diameter.
We removed the focusing lens and the dents are in the actual top sealed layer of concave glass in the crt itself.
Does the whole red crt have to be replaced or can the flawed glass/seal be replaced? Since he bought the set used he doesn't want to put a ton of money in it...so if there's a cost effective way to fix this please let me know.
Thanks,
Ken
Old 10-19-07, 10:27 PM   #4 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
You might find a used tube that you could change the part from but you would have to replace the coolant as well...a messy job and there are not likely many used tubes for these floating around yet as these sets are not aging out much yet. Mitsubishi sells only the entire CRT assy. I have some older CRTs that I might be able to pull a part from but I would have to have the part to compare, or at least some very detailed pix and measurements.
-Joseph Joubert
Raise the bar.
Old 10-20-07, 02:58 PM   #5 (Link)
New Member
Alias: Ken
Loc: Medina,TN
User: #3512
Since: Oct 2006
KenWH is offline
Thanks again for help.
Do I have to go through an authorized Mits repair company or can I order the crt myself somewhere online?
Do you happen to know the part# for the Red Crt assembly that I need? Again the tv is model# WS-65315.
Thanks,
Ken
Old 10-20-07, 07:43 PM   #6 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
The only place to get a CRT asy is Mitsubishi. You may find a tube rebuilt from VDC, but it may not have the hardware mounted.
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
Mits ws55819 convergence issues Mike Phoebus Video Displays and Processors 5 06-21-08 05:58 PM
MITS VS-50805 Problem JVP Manufacturers Service and Support 13 01-29-08 05:23 AM
Ws-65315 Blinking Green Syndrome toneloc Manufacturers Service and Support 12 11-14-07 12:49 PM
Mits 55819 vertical deflection failure MrPinkNuts Manufacturers Service and Support 10 08-14-07 10:44 PM
Mits VS-50805 problem SAMMY18 Manufacturers Service and Support 1 08-09-07 05:37 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
