| Manufacturers Service and Support Geometry Help With Mits wd-73833Discuss Geometry Help With Mits wd-73833 in the Home Theater | Audio and Video forum; Geometry Help With Mits wd-73833 I just purchased the 73833 and i have adjusted basic geometry via the sm. The problem im going to describe ... |
| | #1 (Link) | |||
| Geometry Help With Mits wd-73833 I just purchased the 73833 and i have adjusted basic geometry via the sm. The problem im going to describe doesnt seem fixable through the part of the sm i was in. The problem i have is that everything tilts up slightly on the left side of the screen. If i put up a test pattern its pretty easy to see. Now that i know its like that i always notice it and it drives me nuts. Is there any way to adjust this? tilt? seems like the picture needs to be rotated slightly if that makes sense. I dont want to swap because this set doesnt have the loud fan others have reported and im afraid the next one will since it seems pretty common. Thanks. Mike | |||
| | #2 (Link) | |||
| Re: Geometry Help With Mits wd-73833 There is no specific tilt adjust on the light engine in the new mits sets. The only way to correct this is to be sure that the set is on a flat surface, wiggle the fram of the screen back and forth to settle the screen and frame, then adjust using the correction points in the geometry adjustments. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| | #3 (Link) | |||
| Re: Geometry Help With Mits wd-73833 Dont know if that will help but i will try. In the sm geometry screen the line that runs horizontal across the screen is what needs to be adjusted. The left side of the line just needs to be lowered a few ticks but this line is not selectable. Thx. Mike | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Mits ws55819 convergence issues | Mike Phoebus | Video Displays and Processors | 5 | 06-21-08 05:58 PM |
| MITS VS-50805 Problem | JVP | Manufacturers Service and Support | 13 | 01-29-08 05:23 AM |
| Red fog in Mits ws-65315 | KenWH | Manufacturers Service and Support | 5 | 10-20-07 07:43 PM |
| New Sony and Mits 1080 Projector comparison | MACCA350 | Home Theater Projectors | 13 | 09-12-07 06:48 PM |
| Mits VS-50805 problem | SAMMY18 | Manufacturers Service and Support | 1 | 08-09-07 05:37 AM |
