Mitsubishi WS65907 Convergence Problems - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Service and Support > Brand Specific Service Forums > Brand Specific Service Forums > Mitsubishi
Mitsubishi
Discuss Mitsubishi WS65907 Convergence Problems in the Brand Specific Service Forums forum; Mitsubishi WS65907 Convergence Problems I am having intermitent convergence problems with my Mitsubishi. I live in a remote area of Missouri, and the closest ...
Old 10-17-07, 05:40 PM   #1 (Link)
New Member
Alias: MIKE
User: #12515
Since: Oct 2007
  MIKEMC is offline
I am having intermitent convergence problems with my Mitsubishi. I live in a remote area of Missouri, and the closest service center I have found is 120 miles away. He told me I would have to bring him the set and that it would cost $600 - $800 to fix it. He suggested I would be better of just replacing the unit. I am fairly handy (not a certified tech by any means) is there anything I can do myself to try to fix this?
I read several posts about resoldering the chips to the board and checking connections and fuses, but when I plugged the set and removed the back I could not determine the location of the convergence control circuit board.
Any help would be greatly appreciated.
Old 10-17-07, 10:37 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: Mitsubishi WS65907 Convergence Problems
You need to look very carefully for coolant leaks and check the solder connections on the convergence output ICs. These are the large chips on the largest heat sink in the set. See the information in the thread on convergence problems in the Manufacturers Service and Support forum.
______________________
Why I support scouting...
Core values taught in Cub Scouts:
Citizenship, Compassion, Cooperation, Courage, Faith, Health and Fitness, Honesty, Perseverance,
Positive attitude, Resourcefulness, Respect, Responsibility.
Old 10-18-07, 05:50 PM   #3 (Link)
New Member
Alias: MIKE
User: #12515
Since: Oct 2007
  MIKEMC is offline
I assume I will have to remove the circuit board to do this, are there any tricks to unplugging the ribbon connectors or any other potential land-mines I should know about? Thanks again for the help.
Old 10-18-07, 07:40 PM   #4 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
  lcaillo is offline
Lift the tinter board connectors evenly on both sides. Look carefully for coolant leaks and corrosion.
« Home Theater Shack > Service and Support > Brand Specific Service Forums > Brand Specific Service Forums > Mitsubishi »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242
