| Manufacturers Service and Support Mitsubishi WS65907 Convergence ProblemsDiscuss Mitsubishi WS65907 Convergence Problems in the Home Theater | Audio and Video forum; Mitsubishi WS65907 Convergence Problems I am having intermitent convergence problems with my Mitsubishi. I live in a remote area of Missouri, and the closest ... |
| | #1 (Link) | |||
| Mitsubishi WS65907 Convergence Problems I am having intermitent convergence problems with my Mitsubishi. I live in a remote area of Missouri, and the closest service center I have found is 120 miles away. He told me I would have to bring him the set and that it would cost $600 - $800 to fix it. He suggested I would be better of just replacing the unit. I am fairly handy (not a certified tech by any means) is there anything I can do myself to try to fix this?I read several posts about resoldering the chips to the board and checking connections and fuses, but when I plugged the set and removed the back I could not determine the location of the convergence control circuit board. Any help would be greatly appreciated. | |||
| | #2 (Link) | |||
| Re: Mitsubishi WS65907 Convergence Problems You need to look very carefully for coolant leaks and check the solder connections on the convergence output ICs. These are the large chips on the largest heat sink in the set. See the information in the thread on convergence problems in the Manufacturers Service and Support forum. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| | #3 (Link) | |||
| Re: Mitsubishi WS65907 Convergence Problems I assume I will have to remove the circuit board to do this, are there any tricks to unplugging the ribbon connectors or any other potential land-mines I should know about? Thanks again for the help. | |||
| | #4 (Link) | |||
| Re: Mitsubishi WS65907 Convergence Problems Lift the tinter board connectors evenly on both sides. Look carefully for coolant leaks and corrosion. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Convergence Prob VS60609 Mitsubishi | tjhol | Manufacturers Service and Support | 3 | 10-21-07 12:13 PM |
| problems with mitsubishi hd1080 | edase | Manufacturers Service and Support | 1 | 09-11-07 01:29 PM |
| ws-55809 convergence | rustamust | Manufacturers Service and Support | 5 | 06-09-07 04:27 PM |
| Mitsubishi WS-65907 Startup Problems | ronludlow | Manufacturers Service and Support | 4 | 05-29-07 03:57 PM |
| Convergence Zone | Roger | Home Theater, Audio and Video News | 0 | 09-01-06 12:30 AM |
