Hello I'm new to this forum. - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Manufacturers Service and Support
Discuss Hello I'm new to this forum. in the Home Theater | Audio and Video forum; Hello I'm new to this forum. Hello, my name is Vern and I live in Seattle, Washington. I'm new to this, so if this isn't the ...
Old 11-01-07, 01:18 AM   #1 (Link)
New Member
Alias: Vern
Loc: Bothell, Washington 98011
User: #12951
Since: Oct 2007
vern90 is offline
Hello, my name is Vern and I live in Seattle, Washington. I'm new to this, so if this isn't the place to post this message please let me know. I have a Mitsubishi WS55809 projection tv that's about 6 years old and has worked without problem until about 3 months ago. When all of the sudden one night when I turned it on the picture seemed to be almost concave or bowed. The colors on each side of the screen are misaligned and seem to be stretched. I'm not sure I am describing it correctly but maybee you know what I am trying to say. Also it doesn't happen all the time, it will go away for a while and then come back unexpectedly, sometimes if I smack the side of the tv it will go away. I'm not sure of what's going on, let me know if there is anything I can do. I am an auto technician so I am somewhat inclined, can this be something I can do myself or do I have to take it in? Thanks alot and please message me to where the answer with be posted.
Old 11-01-07, 01:24 AM   #2 (Link)
Loc: Lower Alabama
Re: Hello I'm new to this forum.
Hi Vern and welcome to the Shack!
We'll get you in the right forum... no problem...
Old 11-01-07, 07:01 AM   #3 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Hey Vern, welcome aboard.
I used to have a Mits. 55805, but it served me well until I sold it, so I can't help you there. I can tell you that there are a lot of Mits experts over at the HT Spot -- which I frequented a lot until they started charging a subscription fee. So if you are desperate, that's an option for advice. But you sound pretty handy, so I would probably contact Mits for a copy of the maintenance manual and you can probably figure out which board is giving you fits and replace it.
Sounds like one of the amps controlling the convergence failed. Based on what you said about hitting it, it is probably a power or output feed from that board that is disconnecting or shorting. It SHOULD be an easy fix for a technician, but I have no idea what it would cost, since it has to be on site. Call Mits and ask, it can't hurt and it may be covered under warranty. Worst case, they can probably steer you towards the right parts/manual.
Best of luck,
Anthony
Old 11-01-07, 09:00 AM   #4 (Link)
Alias: mech
Loc: Empire Township, MN
mechman's Avatar
User: #6446
mechman is online now
Welcome Vern!
mech
mech
Got questions? Start a thread.
Old 11-01-07, 03:15 PM   #5 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is online now
Hi Vern and welcome,
This is a problem that you may be able to fix on your own if your willing to do some work.
First of all do this at your own risk and make sure you unplug the power cord and use caution as there will still be high voltages present even after the power is unplugged.
You will need to open up the back of the set and once inside you will need to go from one spot to the next making sure that all the boards and wires are connected properly. The fact that you say it goes away when you hit the display says to me that you just may have a bad connection somewhere.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 11-01-07, 04:11 PM   #6 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Resolder the convergence output IC. Very common problem on this one. If you catch it early enough you may not have to replace the IC.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support »
Similar Threads
New to the forum DanM Welcome | Member Introduction 8 01-30-07 04:30 PM
New to the forum - my HT garcianc2003 Home Theater Gallery 11 12-14-06 07:14 AM
New to forum. Nuglets Welcome | Member Introduction 2 09-12-06 12:24 AM
Yet another forum... TheSmisker Welcome | Member Introduction 9 07-06-06 02:08 PM
New forum and new moderator... Sonnie Home Theater Design and Construction 2 06-26-06 07:14 AM
Mach 5 Audio
