| Manufacturers Service and Support Top and Bottom of the Screen BowsDiscuss Top and Bottom of the Screen Bows in the Home Theater | Audio and Video forum; Top and Bottom of the Screen Bows I have a Mitsubishi 46" Rear Projection WT-46805. The top and bottom of the screen bows almost like a sideways ... |
| | #1 (Link) | |||
| Top and Bottom of the Screen Bows I have a Mitsubishi 46" Rear Projection WT-46805. The top and bottom of the screen bows almost like a sideways hourglass. I've read the convergence thread and figure I need to replace th IC's. Is the a way to know if just resoldering will fix the problem. Also I have found out that if I tap in a certain place on the bottom of the TV the picture will go back to normal. | |||
| | #2 (Link) | |||
| Re: Top and Bottom of the Screen Bows If tapping affects the problem, then you may just need to resolder. If you let it go too long you will need to change the chips. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| | #3 (Link) | |||
| Re: Top and Bottom of the Screen Bows Its been permanently like that for at least 6 months now. I just figured out that tapping will fix it but only for about 2-4 minutes. If I do need a service tech do you know any in Phoenix, Az? | |||
| | #4 (Link) | |||
| Re: Top and Bottom of the Screen Bows Chances are that the chips should be changed. I don't know anyone in Phoenix, but I will ask around on the tech lists. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| Thread Tools | |
Similar Threads | ||||
| Not sure how fabric gets "finished" at top and bottom plate of sonosub... | covermye | DIY Subwoofers - Sealed and Ported | 11 | 08-27-07 11:31 PM |
| Sub bottom or amp clip....Please Help! | Vader | Home Audio Subwoofers | 7 | 07-25-07 01:48 AM |
| Spikes on bottom of box? | ccdoggy | DIY Subwoofers | 23 | 03-15-07 12:26 PM |
| Yamaha Bows New One-Box Surround System (YSP-1100) and Home Theater Receiver (RX-V2700) | Chris Boylan | Home Theater, Audio and Video News | 0 | 10-01-06 12:25 AM |
