lcaillo can u help ? HD 1080 red and green shadows - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Service and Support > Brand Specific Service Forums > Brand Specific Service Forums > Mitsubishi
Mitsubishi
Discuss lcaillo can u help ? HD 1080 red and green shadows in the Brand Specific Service Forums forum; lcaillo can u help ? HD 1080 red and green shadows I turned on my Mitsubishi HD 1080 (Model Number WS-65907) yesterday and the picture was split into red and green ...
Old 12-19-07, 04:54 AM   #1 (Link)
New Member
Alias: don63
Loc: orlando
User: #14495
Since: Dec 2007
  don63 is offline
I turned on my Mitsubishi HD 1080 (Model Number WS-65907) yesterday and the picture was split into red and green shadows.
Read on this forum that this could be solder or convergence IC problem.
I live in Orlando area. Can anyone recommend a good service technician (preferably one they've had experience with) or what steps can I take to fix the problem ?
>>> lcaillo - you seem to be located in Gainesville - could you help me out please ? Can you email me your contact details ?
Am reasonably good with a soldering iron, but am scared of the high voltages inside the TV.
Thanks in advance.
Old 12-19-07, 05:25 AM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: lcaillo can u help ? HD 1080 red and green shadows
I do not know any techs in your area, and since you are at least 2 hours from us, travel time would make the repair cost prohibitive. Call around to the local techs and see what they charge for these repairs. This is a very routine problem in most cases, and it is rare to have problems that go beyond the output ICs or their supply fuses in these sets. If a tech is not willing to tell you what they charge for a routine convergence repair and not willing to discuss where they buy their parts as the importance of using original Sanyo chips, then move on to the next shop.
I will ask around for a shop in your area and let you know what I find. If you do not feel confident going into the set, don't do it yourself.
______________________
Why I support scouting...
Core values taught in Cub Scouts:
Citizenship, Compassion, Cooperation, Courage, Faith, Health and Fitness, Honesty, Perseverance,
Positive attitude, Resourcefulness, Respect, Responsibility.
Old 12-19-07, 06:35 AM   #3 (Link)
New Member
Alias: don63
Loc: orlando
User: #14495
Since: Dec 2007
  don63 is offline
Thanks very much !
Not to be a pain, but :
1) I assume there will some soldering to replace the convergence ICs
2) Can you point me at the location of the unit ?
3) Any obvious fuses to check at the same time ?
Thanks again
Old 12-19-07, 06:08 PM   #4 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
  lcaillo is offline
Read the convergence repair thread completely.
Check all of the fuses. They are pico fuses and are labelled on the board. There are also a couple of glass fuses but they rarely fail.
« Home Theater Shack > Service and Support > Brand Specific Service Forums > Brand Specific Service Forums > Mitsubishi »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242
