Mitsubishi 55711 Stuck in Device Menu - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Service and Support > Brand Specific Service Forums > Brand Specific Service Forums > Mitsubishi
Mitsubishi
Discuss Mitsubishi 55711 Stuck in Device Menu in the Brand Specific Service Forums forum; Mitsubishi 55711 Stuck in Device Menu Somehow I am stuck in the device menu on a WS-55711 Mitsubishi. The menu displays constantly and rapidly changes from ...
Old 01-01-08, 12:44 PM   #1 (Link)
New Member
Alias: Tony
Loc: Palm Springs, CA
User: #14951
Since: Jan 2008
  tanderson4 is offline
Somehow I am stuck in the device menu on a WS-55711 Mitsubishi. The menu displays constantly and rapidly changes from one device to another. Neither the remote nor front panel controls are responsive. Have tried system reset (repeatedly), and unplugging and leaving TV off for up to 24 hours without any improvement. I have also tried every combination of control panel key presses I could think of. Error codes display as 1-2 which as I understand are normal. If I power up the TV and leave the power button depressed while powering up, the display comes up without the device menu; however, as soon as I release the power button, it returns. In this state, the TV completely ignores the remote.
Any thoughts would be much appreciated. I have tried everything I can think of over the past two days trying to get rid of the device menu to no avail. I keep hoping there is some magical combination of front panel button presses that will get rid of the device menu.
Thanks to all. Happy New Year.
...Tony
Old 01-01-08, 03:32 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: Mitsubishi 55711 Stuck in Device Menu
Most likely a stuck front panel button or defective tact switch there. I would unplug the connector going to the control panel and see if ou have response with the remote.
______________________
Why I support scouting...
Core values taught in Cub Scouts:
Citizenship, Compassion, Cooperation, Courage, Faith, Health and Fitness, Honesty, Perseverance,
Positive attitude, Resourcefulness, Respect, Responsibility.
Old 01-02-08, 12:23 AM   #3 (Link)
New Member
Alias: Tony
User: #14951
Since: Jan 2008
Leonard...
Thank you for the suggestion. I will attempt to figure out how to disconnect the control panel and see if that fixes things. That theory certainly fits the symptoms, although I had not touched the control panel when the problem occurred. But I'll give it a try.
Thanks for taking the time to reply on New Year's Day!
...Tony
« Home Theater Shack > Service and Support > Brand Specific Service Forums > Brand Specific Service Forums > Mitsubishi »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242
